HPR 115(Average White Boat)
  • Bp9145
    • Jan 2016
    • 1466
    #91
    That's some nice work Shawn. The paint job is so simple, clean of clutter and yet so elegant especially with the stripe combo with the fine little details in it. . . .just love it. . . .very nice indeed. I can't wait to see it zip on the water.
      Thanks guys, it’s so nice to get it this far and have it turn out ‘by my own hand’.
      Thanks for the praise,
        • 4338
        #93
        You really banged this one out quickly, without cutting corners. Your experience shows. It must be exciting to know its going to hit the water soon!
        And I agree with Brian, your layout of the graphics is dead nuts on. Clean and simple.
        • CraigP
          • May 2017
          • 1464
          #94
          It’s a great build Shawn! That thing is going to look and sound so good out on the water, I can hear it now!
            Yes, yes it shall! So happy to be at this point already. So the LMT’s are in and while there I thought I’d share the tricks that make install and removal easy on me. Perhaps you guys can put it to use.
            9036D09E-38FA-4A93-91B2-26DC347E1494.jpgF0CC104B-A03D-42B4-BA04-F0FB112D6855.jpg9AD5DEF5-C236-4C64-BA93-3C90C5140185.jpg
            I fashioned a hex bit onto a .130 flex which goes into my tool kit nut driver. After much futzing and dropping of screws I came up with the loop in the brass wire which gets used as a guide for the screw/hex. Works like a charm!
            • Beaux
              • Dec 2015
              • 550
              #96
              Cool tool.
                I have ESC’s wired, programmed and installed. ESC cover plates installed. Added a foam bed on sponson floor by ESC’s for batteries to sit on.
                Servo, hydraulics, and cables and cable clamps(courtesy of Kent @cfparts) installed. I had changed servos as I decided to run HV radio system in this one. I’m just going to try it out and see if range increases, hasn’t been a problem but I do know my limitations on the lake.
                I am working on the wiring for the Rx and data tower but figured I’d show off what takes the place of the logger and still holds the Rx battery.
                  And it’s alive!!! Swordy’s seem to be sync’d up well. But one doesn’t wanna beep a cell count. I’ll reprogram and see.
                  • dmitry100
                    • Mar 2015
                    • 1264
                    #99
                    I'll just leave this here... I don't think I would ever be able to unscrew anything without this flexable screwdriver: https://www.amazon.com/ORIA-Screwdri...ewdriver&psc=1
                      That’s a nice setup Dmitry. I don’t know if it would get the bottom screws though. In my instance anyway. But it sure looks like a handy one.
                        So on the ‘last finishing touches’ front, I am so impressed with myself on this one.
                        On these 115’s the hatch fits loose, real loose! So after measuring I decided that a great option would be foam tape stuck to the outside edge of the hatch. So after much searching I found a single roll of 1/16” sticky one side tape on eBay. I installed this morning and now the hatch fits nice and snug. This should be my seal
                          • 4338
                          #102
                          Wow, you weren't kidding. That looks like a hood gap on a car! Looks like that tape was a perfect fit.
                            I know right. I’ve never ran across it before. But it’s like it was meant for this. And it’s awesome! Love it when it works out.
                            • dmitry100
                              • Mar 2015
                              • 1264
                              #104
                              Did you use any extra adhesive for the foam? I'd imagine it would eventually start coming off after getting wet several times
                                Dmitry I think it should be good as the foam tape is 3M for automotive use.
