That's some nice work Shawn. The paint job is so simple, clean of clutter and yet so elegant especially with the stripe combo with the fine little details in it. . . .just love it. . . .very nice indeed. I can't wait to see it zip on the water.
HPR 115(Average White Boat)
You really banged this one out quickly, without cutting corners. Your experience shows. It must be exciting to know its going to hit the water soon!
And I agree with Brian, your layout of the graphics is dead nuts on. Clean and simple.Vac-U-Tug Jr (13mph)
Yes, yes it shall! So happy to be at this point already. So the LMT’s are in and while there I thought I’d share the tricks that make install and removal easy on me. Perhaps you guys can put it to use.Originally posted by CraigP View PostIt’s a great build Shawn! That thing is going to look and sound so good out on the water, I can hear it now!
9036D09E-38FA-4A93-91B2-26DC347E1494.jpgF0CC104B-A03D-42B4-BA04-F0FB112D6855.jpg9AD5DEF5-C236-4C64-BA93-3C90C5140185.jpg
I fashioned a hex bit onto a .130 flex which goes into my tool kit nut driver. After much futzing and dropping of screws I came up with the loop in the brass wire which gets used as a guide for the screw/hex. Works like a charm!
I have ESC’s wired, programmed and installed. ESC cover plates installed. Added a foam bed on sponson floor by ESC’s for batteries to sit on.
Servo, hydraulics, and cables and cable clamps(courtesy of Kent @cfparts) installed. I had changed servos as I decided to run HV radio system in this one. I’m just going to try it out and see if range increases, hasn’t been a problem but I do know my limitations on the lake.
I am working on the wiring for the Rx and data tower but figured I’d show off what takes the place of the logger and still holds the Rx battery.
I'll just leave this here... I don't think I would ever be able to unscrew anything without this flexable screwdriver: https://www.amazon.com/ORIA-Screwdri...ewdriver&psc=1
That’s a nice setup Dmitry. I don’t know if it would get the bottom screws though. In my instance anyway. But it sure looks like a handy one.Originally posted by dmitry100 View PostI'll just leave this here... I don't think I would ever be able to unscrew anything without this flexable screwdriver: https://www.amazon.com/ORIA-Screwdri...ewdriver&psc=1
So on the ‘last finishing touches’ front, I am so impressed with myself on this one.
On these 115’s the hatch fits loose, real loose! So after measuring I decided that a great option would be foam tape stuck to the outside edge of the hatch. So after much searching I found a single roll of 1/16” sticky one side tape on eBay. I installed this morning and now the hatch fits nice and snug. This should be my seal
