I'm ADDICTED!!!!! Another Cat build
  • zanda
    • 139
    #46
    im building up the same boat at the moment . twin brushless from the aqua craft super vee 27 L36\56 7.2-18v. almost ready to hit the water just not sure on what battery to run and prop. do i need to get a left and a right hand prop ?
    • ozzie-crawl
      • Sep 2008
      • 2943
      #47
      yes you need left and right hand props and flex cables, unless your running wire drives
      • zanda
        • 139
        #48
        what will happen if i dont do this ? i no its probley a stupid question
        • ozzie-crawl
          • Sep 2008
          • 2943
          #49
          counter rotating inward props will make it alot easier to setup and get running properly and you need left and right hand wound flex cables other wise they will unwind
          • Simon.O.
            • Oct 2007
            • 1611
            #50
            Or as Scott said before you can use wire drives and not worry about cables shrinking, / unwinding etc.
            You can also swap a couple of motor wires and change from inward rotation to outward rotation in about 2 minutes.
            Depending on hull setup and your choice of running style, saw, oval or fun you get to choose.
            I do not have twin cat yet but have done a fair bit of research.
            Scott will help you and I'll point you to some others who know the game too.
            Enjoy.
            • zanda
              • 139
              #51
              well i have the stock flexy cable of the super vee 27 where can i get another thats oposite wined and same size ? any idea of a good octura props? thanks for ur help
              • ozzie-crawl
                • Sep 2008
                • 2943
                #52
                this is what you need http://www.offshoreelectrics.com/pro...oct-oc150R-24c
                as far as props you can get octura left/right x442s, but you may want to try some cheaper carbon props first to get an idea
                • Team FFRB
                  • 328
                  #53
                  Originally posted by lomdel View Post
                  What rudder and stingers were those?
                  Hi Lomdel,
                  Hopf gear.
                  HOT RODS ON WATER
