I'm ADDICTED!!!!! Another Cat build
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    Tony, Ray at Fullers will supply .150 if you ask for it on his cat offshore hardware.
    Spot what a bummer on your hull. I avoid UPS like the plague
    Douggie
    • rockwerks
      • 772
      Douggie
      man that sucks...............I hate UPS..........I send everything USPS is I can, if not it goes FED EX..............Id rather DHL but not available where I am
      I think you will like the 4mm stuff and easy to adapt to 3/16 props the cable and output shaft are captured and cant fall out............Im using some of the stuff on an BJ26 rehash
      an RC rock crawler lost in a sea of boat parts.........
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        re :
        Thanks for the info, guys. Gives me something to think about. Since I'll likely transplant my 1515 1Y, I'll need to run a .187 cable to be on the safe side. I've been running this setup [ Fine Design 21 EGRSA ] with a .187 in the tube setup for the original .130, minus the teflon liner in the Drifter. Works well, & the drive can configure the rudder on either side. I like a left-side rudder on cats to lift the outside chine in right turns to avoid the chine "trip & flip," a well known Drifter characteristic Ray's hardware might work as well.
        • focused
          Dutch Electric Powerboats
          • 237
          Originally posted by Spot Me 2 View Post
          Well this just got put on hold. When I recieved the hull on Sat, it was damaged. This is the second boat in a row the UPS damaged in shipping. The first was a MHZ hull and now this one. If I didn't have bad luck, I wouldn't have any at all.
          Oh no ,
          that looks very bad , i was very lucky that my order with 3 boats came with no damage at all .
          Did you mail mr Cheung yet and send him the pictures maybe he will send you a new one in a bigger box .
          Michiel.
          • Spot Me 2
            • 770
            WOW, packed like that your lucky they weren't damaged!!!! Ay least 2 of them are wrapped in bubble tape. I didn't buy from him.
            MMGMMarine
            RobertsonRacing
            • rockwerks
              • 772
              that was your problem, they are great to deal with
              • Spot Me 2
                • 770
                The guy I got it from took it back. He gave me all my moneyback, even shipping, and paid for shipping back to him. Thats a standup way of running a business!
                MMGMMarine
                RobertsonRacing
                • rockwerks
                  • 772
                  True, cant complain about that
                  • Spot Me 2
                    • 770
                    The new hull and hardware came today.
                    Time to start building.
                    MMGMMarine
                    RobertsonRacing
                    • Spot Me 2
                      • 770
                      I think I want to see what I can do on 3s with this hull. My mean machine build is going to be my lightning fast cat. I was thinkng of using a Fiego 8s motor and my HiModel 200amp ESC.
                      I have the motor and esc already. What prop would you guys start with for this combo???
                      MMGMMarine
                      RobertsonRacing
                      • focused
                        • 237
                        Are you sure you want to do this . The s8 has a rev of 4436/volt on 3s = 50K/min.
                        start with a 34mm prop .
                        Michiel.
                        • Spot Me 2
                          • 770
                          I would prop up a little to keep the rpms down. I have 200 amps to paly with. With a X632 prop, FECalc has it spinning at 37,249.16 RPMs
                          MMGMMarine
                          RobertsonRacing
                          • j.m.
                            • 847
                            That motor won't be able to handle 200 amps running through it.
                            I would use an L.
                            • Spot Me 2
                              • 770
                              OK. I have decided to go with a nemesis 6xl, Hydra 120a, on 3s starting with a x632 prop. Set up correctly, I expect to run mid 40s. With some tuning, maybe low 50s????
                              MMGMMarine
                              RobertsonRacing
                              • j.m.
                                • 847
                                okay.
                                That'll be MUCH better.
