You can see the two drill holes in the hull's side.
That little chip is the voltage regulator for direct power to the LEDs. I got both 5mm and 8mm, but will use the 5mm. I may add the smaller diffused 3mm to the inside of the hull. After all, if you will be out late enough to actually use the nav lights, some internal lighting wouldn't hurt.
I also got to mock the decals up. They will most likely be silver or black, but I still need to figure out where I'm going with the boat itself. The pieces you see on the paper will be "carbon". Yes I recreated the original canopy.
Sent from my Pixel using Tapatalk
