FDM 32 V-Hull Build - Need Build Advice
  • Tamelesstgr
    • Jun 2014
    • 1512
    #46
    Seriously frustrated this week. The 200 amp logger isn't working, The spark arrestor I built does not arrest the spark on 6s. Thinking about selling all this MISC stuff and just getting a Zelos 36 or something.
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • Tamelesstgr
      • Jun 2014
      • 1512
      #47
      Made some progress with a solution for securing my battery straps, and fabricated some aluminum tabs to secure my hatch. Added 2-part foam to my hatch and sanded everything in prep for paint. Finally!!
      • Tamelesstgr
        • Jun 2014
        • 1512
        #48
        Onto the main hull color, Gloss Orange
        • Tamelesstgr
          • Jun 2014
          • 1512
          #49
          2nd Orange coat, going to let this cure about a week.
          • Tamelesstgr
            • Jun 2014
            • 1512
            #50
            Painted the hull bottom and hatch, starting to apply decals, getting closer
            • Beaux
              • Dec 2015
              • 550
              #51
              Nice looking boat, won't be long now.
              • Outboard
                • Jan 2016
                • 50
                #52
                What type of paint did you use?
                GO HARD OR GO HOME
                • Tamelesstgr
                  • Jun 2014
                  • 1512
                  #53
                  Rustoleum Painters Touch, but I won't be using that anymore, I'm going to try Lacquer.
                  • Tamelesstgr
                    • Jun 2014
                    • 1512
                    #54
                    Decided 2 coats of clear is sufficient for now, want to get this thing wet after over a year. Starting to put all the pieces together.
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      #55
                      Switched the rudder mount to the Starboard side of the bracket giving me just enough room to sneak the flex cable past the rudder. When I had it setup inline I would have to disconnect the rudder blade and pushrod each time I have to grease the flex. Bent and cut a pushrod, and installed all the hardware on the transom, getting closer!
                      • Tamelesstgr
                        • Jun 2014
                        • 1512
                        #56
                        99% buttoned up, need to cut a slot in the flex shaft to secure the drive dog, program esc, and leak test. Travelling this week for work, so a little bummed I have to wait some more to see if I am successful.
                        • Tamelesstgr
                          • Jun 2014
                          • 1512
                          #57
                          Some Before and After
                          • Tamelesstgr
                            • Jun 2014
                            • 1512
                            #58
                            Came up with an offset rudder solution this weekend, but now I can't get my Seaking 180 to respond. Have previously hooked up 3s and 6s batteries to test that the servo is working correctly and that the end points are where I want them. So I got all that settled and went to pulg my EagleTree unit in along with the 6S2P and nothing is happeneing, no beeping form the ESC, no motor movement. I had plugged a battery in earlier in the day and it was fine. The lights on the EagleTree also were on. I have since pulled all the EagleTree items out for the time being, still no response from the ESC. I reset all the stock parameters on the Traxxas TQi controller I am using, that didn't help. I am going to try the throttle range calibration tonight. I hope I don't have a dead 180. Caps all look good on the esc and on the cap bank.
                            • Outboard
                              • Jan 2016
                              • 50
                              #59
                              Why is that?
                              GO HARD OR GO HOME
                              • Tamelesstgr
                                • Jun 2014
                                • 1512
                                #60
                                In my experience the Enamel paints take too long to cure fully. You must recoat within 1 hour or wait till that coat is fully cured (sometimes even after 4-5 days I would get peeling / cracking when trying to recoat)
                                I have heard and read that Lacquer you do not have to wait for curing to take place, but I have not tried it for myself yet.
