FDM 32 V-Hull Build - Need Build Advice
  • Tamelesstgr
    • Jun 2014
    • 1512
    #76
    Ran again this weekend with the X442 and after andjusting the trim tabs and turn fins the hull is running very well.
    Max Amps = 99.19
    Max Watts = 2,221
    Max RPMS = 33,557 (Average loaded around 30,000)
    Max MPH = 44.3 (up from 35mph)
    Motor Max Temp = 101.3
    ESC Max Temp = 91.3
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • Tamelesstgr
      • Jun 2014
      • 1512
      #77
      Finally a video:
      • Tamelesstgr
        • Jun 2014
        • 1512
        #78
        Pushed the hull past 48mph yesterday, all though I haven't changed anything, just calm water and I ran accross the entire pond, perhaps it built up more speed. Then I discovered this hull doesn't turn left very sharply and ran up on the rocks a wee bit. Scuffed the bottom and pushed the rudder and turn fin back a little bit. No damage to the prop thankfully, just my pride.
        • Tamelesstgr
          • Jun 2014
          • 1512
          #79
          Ive been making some runs the past few weekends trying a few different size props. They are predicting 40's and flurries here for Chicago this weekend. I've had the most luck with the X442 prop I have, best MPH so far. I tried my X445 and the amp draw was lower than the X442 which I didn't expect at all, about 30% lower. I've got about 6 datalogged runs for each prop and the X445 is consistently lower despite more pitch. Then I tried my X642 this past weekend, and again the readings are lower than the X442.
          X442 - Average over 6 runs
          Amps = 102
          Watts = 2,346
          Top MPH = 48.6
          X445 - Average over 6 runs
          Amps = 77
          Watts = 1,870
          Top MPH = 45.3
          X642 - One run
          Amps = 65
          Watts = 1,716
          Top MPH = 40.4
          I was really stumped by the X642, I wonder if it is too much pitch for a boat that is so heavy like mine running 6S2P? Loaded RPM's are all pretty consistent between all 3 props, about 29,000 - 30,000 rpms. Pond behind my house has been pretty calm the last few weeks
          • Tamelesstgr
            • Jun 2014
            • 1512
            #80
            Video from today, probably the last of the boating season for me.
              • 4340
              #81
              Oh c'mon. If I had that pond in my backyard, I'd be out there until it froze over, running back inside in between runs to thaw out my fingers.
              • Beaux
                • Dec 2015
                • 550
                #82
                Man the boat really looked strong, nice job.
                • Tamelesstgr
                  • Jun 2014
                  • 1512
                  #83
                  With every new prop I have tried it has gone slower lol. X442 is the fastest thus far. Still have some 3-blades to try. The X445 is running second place, the X642 has not performed like I thought.
                  • lt130th
                    • Apr 2014
                    • 858
                    #84
                    Finally got this one in the water! Looks great!
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      #85
                      I'm going to start modifying the strut/rudder assembly to accept more than 43mm prop. This 4082 wants a bigger prop to push
                      Also need to cut a new flex I ordered from OSE, need more shaft length for the larger props.
                      • Tamelesstgr
                        • Jun 2014
                        • 1512
                        #86
                        More room for bigger blades, I just picked up an M545, and M447
                        Should be good to crack 50+ on this pig of a hull
                        • Tamelesstgr
                          • Jun 2014
                          • 1512
                          #87
                          Got some video this Sunday, topped 50mph, gotta pull my datalogs yet.
                          • Tamelesstgr
                            • Jun 2014
                            • 1512
                            #88
                            When I built this boat I didn't really have a good way of securing the hatch with anything other than hockey tape. I wanted some mechanical fastening to keep the hatch from separating if there was flip or high speed tumble. So I drilled and tapped some aluminum, it's held up for maybe a year, but the threads got stripped out. I searched for some Stainless M3 fastener that I could add to the bracket. On RcGroups I learned this is a rivet nut. I resized the holes in the brackets and epoxied these in last night. Hope to see how well they set today.
                            • Tamelesstgr
                              • Jun 2014
                              • 1512
                              #89
                              Pulled my datalogs as well from the day I ran 3 sessions. kind of neat to see the consistency between runs:
                              NSR 32 Leopard 1450kv 6S M545 Prop 4-23-17 Gauges S1.JPG NSR 32 Leopard 1450kv 6S M545 Prop 4-23-17 Gauges S2.JPG NSR 32 Leopard 1450kv 6S M545 Prop 4-23-17 Gauges S3.JPG
                              • Tamelesstgr
                                • Jun 2014
                                • 1512
                                #90
                                Usually I graph each individual session, but I left all 3 in the chart, kind of cool to see them in succession. I'm a little suspect about the ESC graph, it looks like the third run the temps crept up a bit, but I do recall that run was maybe 30 minutes after the last run.
                                Graph 1 = RPM
                                Graph 2 = ESC Temp
                                Graph 3 = Amps
                                Graph 4 = Voltage Drop
                                NSR 32 Leopard 1450KV 6S M545 Prop 4-23-17 RPM Chart.jpg NSR 32 Leopard 1450KV 6SM545 Prop 4-23-17 ESC Temp Chart.jpg NSR 32 Leopard 1450KV 6S M545 Prop 4-23-17 Amps Chart.jpg NSR 32 Leopard 1450KV 6SM545 Prop 4-23-17 Pack Volts Chart.jpg
