Kbb 34" mono build
  • rearwheelin
    • 2101
    #316
    I'm in the dark when it comes to the rules and limits of each class. Lol
    That was me 5 years ago . I didn't do my home work when I went down to the SoCal SAWs. Each class has a mah limit so be sure there are no surprises with your batteries.
    --Albert Einstein
      Any idea where I can find this info
      • complacent_one
        • 111
        #318
        • rearwheelin
          • 2101
          #319
          Right here doggy ! lol
          --Albert Einstein
          • flraptor07
            • Aug 2013
            • 2451
            #320
            Travis go to section 28 that will give you the mah limits per class and the hull length limits. Like I said in my earlier post I'm pretty sure you can run that boat in classes P Q and S if you want just by changing Cell count and not exceding the mah limits. I have heard some talk about them not letting people run Revolectric batteries but then I also heard that they would as long as they were'nt charged over 4.20 per cell. So that I'm not sure about.
              I don't think at this point I have any of those records in the bag. Q mono is 82.357 which allows 6 cells and mine runs 70 on 6 cells. I could do a motor swap but that's another 500 bucks that I don't have lol. I could likely get mid 70's on 6s but I don't think I can get over 82 with my setup now. I may play with some bigger diameter but low pitch props and see how it acts but I don't think it'll be enough. Maybe impba has some softer records but namba doesn't seem to.
              • flraptor07
                • Aug 2013
                • 2451
                #322
                I'm just sayin the classes you could run it in, but you're all over the S record on 8s and that's legal!
                  Ok. I looked at the chart and made my own chart. I could theoretically break the s mono record with what I have. The q mono record could be broken too if I did a motor/kv swap and was still able to keep amp draw under control. I dunno, seem like a lot of money and trouble to do something that not many people care much about, you know? I have a 2250 lehner that came in yesterday that's one step higher on the kv chart than my 2260....I may toss it in this weekend and see it I can hit 80 ish on 6s.
                  • Roy Van De Sande
                    • Nov 2013
                    • 143
                    #324
                    Hello Travis, how high are your amp readings from the mgm esc?
                    Thanks!
                    Roy
                      Thanks!
                      Roy
                      Last I checked it was 240ish and sometimes 270ish depending on prop. Right now I'm trying to maximize what I have and make it more efficient. Just a rudder swap picked me up 3mph and I might can go even shorter.
                      • monojeff
                        • Nov 2010
                        • 2728
                        #326
                        Not to many people might care about it but be pretty cool to be part of the history/record books IMO!
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • keithbradley
                          • 3671
                          #327
                          The only NAMBA SAW events in the country are in California, which is why I assumed you would run in IMPBA. The S record is pretty soft in IMPBA, but that doesn't mean it will be at the end of the year, so keep that in mind. I still don't understand why we're even talking about Q or P. The boat isn't too big for those classes, but the voltage is too high. Theoretically you could put a different setup in it and run Q or P, but for that matter, so could everyone else. I'm not sure when the next Huntsville event is but that's probably the closest to you. There's an event in Flint, MI the first weekend in may. If you wannna fly out you can ship the boat (and whatever else) to me. I have a generator, tools, etc. you could use.
                          www.keithbradleyboats.com
                            Thanks for the offer and that would be awesome and probably a great time....I just don't know if it would be doable any time in the near future. I might would be able to attend a Huntsville event a good bit easier but I'm not sure just yet. I've still got some learning and some work to do.
                              Travis, Congrats! Awesome runs! Man, the boat is planted on the rails.
                              • rayzerdesigns
                                • Dec 2013
                                • 1228
                                #330
                                Yes sir!
                                So what is a very cut rudder
