BBY SS-30 Sport Hydro "Orange Crush"
  • flraptor07
    • Aug 2013
    • 2451
    Here's the latest build it's a BBY SS-30 Sport Hydro Carbon Fiber version. Motor Neu 1515 1Y 2200kv, ESC Swordfish 220 pro plus data logger, KST billet servo 347oz., Speedmaster strut and rudder, HRC Motor mount and cooling can. Randy builds a nice little boat you guy should check them out, I'mm getting a twin motor Rigger from him next. Going to maiden it this weekend, Hopefully bill will get a video, he usually does. Here's some pics to check out!DSC02560.jpgDSC02562.jpgDSC02563.jpgDSC02564.jpgDSC02566.jpg
  • flraptor07
    • Aug 2013
    • 2451
    More Pics!
    • flraptor07
      • Aug 2013
      • 2451
      More Pics!
      • flraptor07
        • Aug 2013
        • 2451
        Last ones!
          Very nice! Is that a thrust bearing I see on the strut? Between the drive dog and strut?
          • flraptor07
            • Aug 2013
            • 2451
            Thanx Travis and yes it's a thrust bearing, I use them on almost all my builds. It puts the load directly on the strut and you don't need to run that big gap.
            • PowerDemon
              • 351
              The sharpie on the prop is awesome! Great way to identify props quickly. Love the flake paint job!
              37" Fightercat Shocker powered by Neu 1530 on 10S
              • flraptor07
                • Aug 2013
                • 2451
                Thanx man, Believe it or not the sharpie stays on pretty good too! Randy does the flake in the Gelcoat when he builds the boat.
                  • 9438
                  A Y547 on a 1515 1y, wow, is that thing pulling major amps or is the prop cut down?? Many people I know only run like a x642 on the 1515 1Y.
                  I dislike metal flake but, it's a sweet boat to say the least.
                  Stuffing tube has a very sharp bend in it too, could be a lot smoother than that.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    Thanx Ray, The tube was bent on a little mandaral bender I have it's really a nice uniform bend. I ran that prop on the Popeye with the same setup and it ran cool enough, usually around 120-125.
                    • RandyatBBY
                      • 3915
                      "Orange Crush" I like that. Nice bunch of pictures, Thanks for the positive plugs.
                      Randy
                      BBY Racing
                      • flraptor07
                        • Aug 2013
                        • 2451
                        No problem Randy, thank you for building me this nice boat. Jeff "Mono Jeff" is printing me up the Orange Crush Logo decals.
                          • 9438
                          The Popeye is a different animal than this I would think being it's hull design is a good 40 years old. The Popeye packs a lot of air compared to this hull. Hopefully you don't burn anything up. I'm not slammin, just talking too much. With the popeye, you would have the prop high loke Doby correct? If so you would only be riding on the tips of your prop not a larger portion like you might on say a Whiplash or maybe this hull. I don't know Randy's hulls too much, only had an old Volcanic splash that was really cool.
                          Randy, what say you on prop choice? Am I way off here? I thought at best a 1y would only push up to a 45mm prop but, that depends on the prop and lots else like hull design. Maybe it's a 645 I was told, never mind I'm rambling because Larry is late and I'm Hangry.
                          • flraptor07
                            • Aug 2013
                            • 2451
                            You might be right Ray, I think I might back up some on the prop to start with. I can always go bigger, but it's hard to go smaller after everything is burnt up!
                              • 7277
                              Do the batteries go in the sponsons? If so, where do you find metal-flake tape????
