BBY SS-30 Sport Hydro "Orange Crush"
  • RandyatBBY
    • 3943
    #31
    I got your graphics done today I am packing then this afternoon and should be in the mail tomorrow morning. Chris did you get a test run last weekend or decide to wait until after the graphics and clear coat was done?
    Randy
    BBY Racing
    • skeeler
      • Jul 2007
      • 208
      #32
      fflraptor07, that thrust bearing seems like a good idea. What do you do to prevent corrosion of the the bearing?
      Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
      '09 Miata.
      Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
      • flraptor07
        • Aug 2013
        • 2451
        #33
        Grease and Corosion X after every outing.
        • skeeler
          • Jul 2007
          • 208
          #34
          Thanks for the info.
          '09 Miata.
          • flraptor07
            • Aug 2013
            • 2451
            #35
            Decal
            Randy I took a quick pic of the decal so you could see what it looks like, I just had to.DSC02593.jpg
            • Shooter
              Team Mojo
              • Jun 2009
              • 2752
              #36
              Thanx Travis and yes it's a thrust bearing, I use them on almost all my builds. It puts the load directly on the strut and you don't need to run that big gap.
              Cool. Are you running a square slip drive (like the old K&B outboards) at the motor so it can slide and put ALL the thrust on the strut?
              • flraptor07
                • Aug 2013
                • 2451
                #37
                No I don't run the square drive and I wouldn't say it puts ALL the load/thrust on the strut but it puts more of the load than a normal setup on the strut
                • jhl1963
                  • Apr 2014
                  • 77
                  #38
                  Love the orange! Any more detail on the lexan hatch attachment/sealing? great idea. Beautiful boat.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #39
                    THANX! There's not much more detail to it, it's just a piece of 1/16 Lexan then I made a form from a 2x4. Then took my handy dandy heat gun and heated the Lexan and pushed it into the form to make the bubble for motor clearance, let it cool. Then cut it to fit the recess in the hatch opening. I tape it down with hatch tape (Hockey tape) when running it, that's about it.
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #40
                      And BTW guys there should be video on this thing this weekend finally!
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #41
                        Maiden Voyage!
                        https://www.youtube.com/watch?v=CmwL...4Q-xrOOtP2C-8w Got some tuning to do yet but I think it's gonna be pretty fast when I get it dialed in......https://www.youtube.com/watch?v=VhBR...ature=youtu.be
                        • RandyatBBY
                          • 3943
                          #42
                          It is looking good and can be better, in the second video while it has a set..... it is smooth. Once the prop winds out the whole boat is lifting from the transom and the whole boat is loose. De-lift the prop a little and drop the strut. I have to run mine that way. Also check to make sure AOA is evan a little off and can cause troubble. Looks like it will be fun once it is dialed in.
                          Randy
                          BBY Racing
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #43
                            Got ya on the prop and strut but what's AOA? and what is causing the left Sponson to flop up and down so much? Maybe turn fin pulling the right down too much?
                            • RandyatBBY
                              • 3943
                              #44
                              AOA is Angle Of Attack. If the angle of attack is more on the port side that could cause it to flop. But I almost always have the Starboard side up a little more to counter act the turn fin. Check the rear for the sponsons to see how they are set.
                              Randy
                              BBY Racing
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #45
                                Are you talking about the way you have the ride pads ground on the sponsons?
