Over clocking the old T29 project
--Albert Einstein
Did I mention I love these things !
This right side needs some negative added. Good thing I'm going threw the hardware bolts because it's all coming loose. I guess I will go ahead and use thread lock and use some sealant on the hardware this time, I was getting about a ounce or less of water in the boat during runs .
--Albert Einstein
--Albert Einstein
So the hobby guy at the shop talked me into trying the 5" 4-40 turn buckle for a servo rod, seemed like a good idea when I was collecting up my build do dads. Well the darn thing busted when I was readjusting it to work with my longer servo arm ! I had like three bends in it and was never really happy with the way it turned out so good riddens to it.
Back to old school style rod , my trade mark piano wire, 4-40 threaded cuffs , JB welded inside and out and center punched and 1 bend. Best easy to do strong servo rod I can come up with, has never let me down in the past
--Albert Einstein
--Albert Einstein
--Albert Einstein
Looks great I really enjoy watching builds where people are creative and make all their own parts. Keep up the great work !!!!!!!!my youtube videos http://www.youtube.com/user/chris81983?feature=mhee
Her is the first run with the x642 2 blade
We made the fishies jump today !
Video : http://youtu.be/Hfi4mgU5f-ULast edited by rearwheelin; 08-24-2014, 06:36 PM."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Here is the second vid. Putting the positive adjustment surely shaved speed but gained some stability. I am waiting on some new struts to come in so I can do another ride plate, I pretty much destroyed any chances of getting this strut right when I tried braising an aluminum one on because I sanded the perfectly machined contours of the strut trying to make it usable again. I'm satisfied all in all I at least got to run it ! Next ride plate will be more flush with the keel so there isn't so much drag, also the positive adjustment could be pushing more water away from the prop. I defiantly am liking the x642 2b. There was a barily marginal increase in esc and motor temps, there is much more room to push harder there
Second run vid : http://youtu.be/asBEaDBzo5M"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
After getting some advice from a very reputable boater out on the East Coast it was suggested that I space the fins out to relieve some of the fin wash pressure, said I need to see daylight between the tab and fin or it can cause the rocking, I put a quarter inch spacer see how it goes. Also when a boat is at this level I needed to sharpen the leading edge of the rudder and round the back bottom, I put a very slight taper from the back to the leading edge. These couple things can make the difference on a boat this size when speeds start going over 35 mph. Basically he motivated me a little for this weekend
--Albert Einstein
--Albert Einstein
Well here the mods , more defined trim and water to the prop . Hoping for more speed threw the turns and straight line stability .... And more speed in general. Still waiting on my new struts , I have more positive than I want and I know it's cutting speed right now but there is nothing I can do until I make the hole threw the transom so that I can move my brass up and down , I knew I should have done that but I knew that I would be close !
I ready lol
--Albert Einstein
Thank you Chris ! By the way I seen your HPR 135 on 11s.... Wow !Originally posted by Chrisg81983 View PostLooks great I really enjoy watching builds where people are creative and make all their own parts. Keep up the great work !!!!!!!!"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
