Over clocking the old T29 project
  • rearwheelin
    • 2101
    #91
    I'm not sure if these turn fins are working
    --Albert Einstein
    • rearwheelin
      • 2101
      #92
      Okie dokie here we go ! Round 3
      --Albert Einstein
      • rearwheelin
        • 2101
        #93
        Did I mention I love these things ! This right side needs some negative added. Good thing I'm going threw the hardware bolts because it's all coming loose. I guess I will go ahead and use thread lock and use some sealant on the hardware this time, I was getting about a ounce or less of water in the boat during runs .
        --Albert Einstein
        • rearwheelin
          • 2101
          #94
          I went ahead and heavy duties up the clamping forces on the rudder and strut. I'm soooo over the stainless lock nuts, they are a PITA !
          --Albert Einstein
          • rearwheelin
            • 2101
            #95
            So the hobby guy at the shop talked me into trying the 5" 4-40 turn buckle for a servo rod, seemed like a good idea when I was collecting up my build do dads. Well the darn thing busted when I was readjusting it to work with my longer servo arm ! I had like three bends in it and was never really happy with the way it turned out so good riddens to it.
            Back to old school style rod , my trade mark piano wire, 4-40 threaded cuffs , JB welded inside and out and center punched and 1 bend. Best easy to do strong servo rod I can come up with, has never let me down in the past
            --Albert Einstein
            • rearwheelin
              • 2101
              #96
              I'm ready to rock and roll tomorrow ! This is a 642x from FDM up first. These pics are to show what the prop see's with the ride plate mod...
              --Albert Einstein
              • rearwheelin
                • 2101
                #97
                My last run I swept back the turn fins and the boat seemed more stable . I swept them back to the max for my next run . I had to sharpen more of the fun doing this.
                --Albert Einstein
                • Chrisg81983
                  • Jul 2011
                  • 1585
                  #98
                  Looks great I really enjoy watching builds where people are creative and make all their own parts. Keep up the great work !!!!!!!!
                  • rearwheelin
                    • 2101
                    #99
                    Her is the first run with the x642 2 blade
                    We made the fishies jump today !
                    Video : http://youtu.be/Hfi4mgU5f-U
                    --Albert Einstein
                    • Vin-m
                      • May 2014
                      • 308
                      #100
                      looking good rearwheelin!!
                      • rearwheelin
                        • 2101
                        #101
                        Here is the second vid. Putting the positive adjustment surely shaved speed but gained some stability. I am waiting on some new struts to come in so I can do another ride plate, I pretty much destroyed any chances of getting this strut right when I tried braising an aluminum one on because I sanded the perfectly machined contours of the strut trying to make it usable again. I'm satisfied all in all I at least got to run it ! Next ride plate will be more flush with the keel so there isn't so much drag, also the positive adjustment could be pushing more water away from the prop. I defiantly am liking the x642 2b. There was a barily marginal increase in esc and motor temps, there is much more room to push harder there
                        Second run vid : http://youtu.be/asBEaDBzo5M
                        --Albert Einstein
                        • rearwheelin
                          • 2101
                          #102
                          After getting some advice from a very reputable boater out on the East Coast it was suggested that I space the fins out to relieve some of the fin wash pressure, said I need to see daylight between the tab and fin or it can cause the rocking, I put a quarter inch spacer see how it goes. Also when a boat is at this level I needed to sharpen the leading edge of the rudder and round the back bottom, I put a very slight taper from the back to the leading edge. These couple things can make the difference on a boat this size when speeds start going over 35 mph. Basically he motivated me a little for this weekend
                          --Albert Einstein
                          • rearwheelin
                            • 2101
                            #103
                            I figured while I was at it I would double the sharpness of the fins too ! The one on the right is the difference ... Keep the masking tape off your screens !
                            --Albert Einstein
                            • rearwheelin
                              • 2101
                              #104
                              Well here the mods , more defined trim and water to the prop . Hoping for more speed threw the turns and straight line stability .... And more speed in general. Still waiting on my new struts , I have more positive than I want and I know it's cutting speed right now but there is nothing I can do until I make the hole threw the transom so that I can move my brass up and down , I knew I should have done that but I knew that I would be close ! I ready lol
                              --Albert Einstein
                              • rearwheelin
                                • 2101
                                #105
                                Thank you Chris ! By the way I seen your HPR 135 on 11s.... Wow !
                                --Albert Einstein
