Im using 1840/2 props in this video with the 3674 motors 2075kv that the zonda came with.
114cm mhz mystic build
Here is the same hull as mine with 1840 props
twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
I personally think 50k RPM is too high for the OP's intentions. 50k is ok for SAW or absolute speed, but quite high for reliability, especially in regards to someone without experience within this type of setup.
Plenty of people have done 2200kv with Chinese motors on 6s so it can be done, but failure rate is much higher than slightly lower RPM setups (of course this is only logical...there is no free lunch). With the early TP motors we found about 40k to be where the likelihood of failure sharply rose. The latest generation is said to be better than the early motors.
I agree with Kent in regards to props. 1.9p props can be a bit tricky to set up. A stinger adjustment will definitely be needed to keep it stable on the water and a 1.4p prop will be much more forgiving...possibly even faster.
Hey Keith as far as a cab bank is concerned do you have any recommendation for two for my set up or should I wait till you have my boat? If wait what's approx price so I can save my pennies?
The hifei cap banks are affordable and work quite well. One on each esc will do.Originally posted by Mattyb1975wahoo View PostHey Keith as far as a cab bank is concerned do you have any recommendation for two for my set up or should I wait till you have my boat? If wait what's approx price so I can save my pennies?
Have you decided on motor and kv yet? As I said in another motor thread the 2200 works but going like 1600-1800kv might be better if inexperienced. 1800 kv on 6s in that boat will run beautifully and very cool also run time will be decent. Ive used the 1600 kv setup for 3seasons and although shes slow sport boating is fun too.
1800kv on 6s with the right props is still somewhere in the mid-high 80's mph, still a fast setup. 2200kv on 5s could be an option also as motors/lipo packs are kinda same price. You could run on 5s then just upgrade the packs when ready for more speed. If going LMT Motors, I would aim to get the motor kv right as too expensive to change.Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
5s 2200kv might be the ticket kent, have you ever run this setup. Its a totally logical setup I imagine run time will be good and what not im curious though how a 5s vs 6s setup with identical rpm reveals itself to data logging. If running TP motors you can buy and sell them losing 50 bucks max but getting it right the first time is probably the choice for the minority that are sane FE boaters.
2200kv/5s/x442 propsOriginally posted by iridebikes247 View Post5s 2200kv might be the ticket kent, have you ever run this setup. Its a totally logical setup I imagine run time will be good and what not im curious though how a 5s vs 6s setup with identical rpm reveals itself to data logging. If running TP motors you can buy and sell them losing 50 bucks max but getting it right the first time is probably the choice for the minority that are sane FE boaters.
74mph
Peak current 160-180A under hard acceleration.
With Keith's help I've decided on 2 2000kv black series motors that way I have some decent speed, room to grow but keep some reliability and costs downOriginally posted by iridebikes247 View PostHave you decided on motor and kv yet? As I said in another motor thread the 2200 works but going like 1600-1800kv might be better if inexperienced. 1800 kv on 6s in that boat will run beautifully and very cool also run time will be decent. Ive used the 1600 kv setup for 3seasons and although shes slow sport boating is fun too.
