114cm mhz mystic build
  • Mattyb1975wahoo
    • Sep 2013
    • 59
    hello everyone,
    I am a relative newb to OSE and RC boat in general. I had a swamp buggy once but I've mainly been in and out of car/truck RC racing. A few months ago I got bit by the boat bug and purchased a Chinese 36" cat from r2hobbies. upon getting it and planning a build I realized it was not up to standards and I started following several threads here and over at KBB trying to learn how to get it to par. After having been following a few builds on this forum I realized what I must do. boatNow I am going to try and borrow knowledge, learn my own and not break the bank in records time building my first real deal fast boat. I am not looking to race nor break any SAW records!!
    My GoaLS are to:
    A) Build a fast, reliable boat that gets decent runtime.
    B) learn quick and try not to make costly rooky mistakes
    C0 Stay away from the trash talking problem people here and make some friends with the awesome guys here. Some of which I've already talked to and or made deals with.
    So far I've seen really awesome stuff here, and found this a good place to get help and ideas.
    This is what I got so far:
    MHZ Mystic C5000 114CM. C/K Courtesy: KM7
    MHZ Rudder Courtesy: KM7
    MHZ Drivers 3/16 Courtesy: KM7
    MHZ Carbon kit Courtesy: KM7
    New motor options 2000kv black series from Keith Bradley
    x2 Seaking 180a ESC Courtesy RCBIDDER
    Spektrum S6070 Digital Servo
    Spectrum transmitter and mr3000
    x2 Large dual water intakes from OSE
    X4 Large water outlets
    I really need some info tips on props ( want to reliably run 65- 85 for decent run times for fun)
    Batter size and quantity to accomplish stated goals
    Type and place to get Cap Banks
    ideas for esc mounts and what not
    Where to get carbon supports and pieces pre cut
    what and how do I connect 2mm holes from drives. * stuffing tubes collets, etc.)
    also I am looking for full size templates for drives
    lastly for now should I run what I brung or CF overlay this boat for longevity and stability?
    Thanks for any and all Info
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Hi, maybe this thread can help a little http://forums.offshoreelectrics.com/...ild&highlight=
    Are you planning to run 6s? If yes 1300kv will get you going but not very fast. I can help you with carbon work and templates for drives.
    • Mattyb1975wahoo
      • Sep 2013
      • 59
      I would like to be between 65=85 on a regular day. what do I have to run with this set up? 6s per side? 10 s per side? 10 s shared in parallel?
      • Mattyb1975wahoo
        • Sep 2013
        • 59
        also ive been reading your old mystic thread. do you still have templates for tube supports, drive stiffening plates and what not
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          Yep, still have everything for that boat. I would run it on 6s max, for the time being. If you one day want to run saw then the 8s might just be what you need. But having the seaking 180 you are limited to 6s. Something in the 1600-2000kv would be a good choice at this point
          • Mattyb1975wahoo
            • Sep 2013
            • 59
            I already have the 1300 kv 4092's gotta do best I can with them
            • Maciek74
              • 48
              minimal RPM for ur props is 25000 so its gonna work (ur setup 6x3,7x1300=28800), optimal for racing is 34-37K so u need more KV on motors or better ESC's to work on 8s, cant do anything else, i would focus on ESC's., sell old ones buy new ones :)
              • Mattyb1975wahoo
                • Sep 2013
                • 59
                that sucks. I just received from rcbidder. should I be looking at hydra 240s or swordfish 300 for most reliability and able to take some abuse from a novice
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  I think SF240's would be plenty!! On 8s at 1300kv amp draw won't be too high. Motors are plenty big also for 47+ props. How ever in your case I would change the motors rather than the ESC's. TP 4050's at around 2000kv or less then you can run on 42 props and step up if you desire more speed. The 2 motors vs 2 HV ESC's are a fair bit cheeper. The 180's are quite good ESC's if you stay at 6s max
                  • Mattyb1975wahoo
                    • Sep 2013
                    • 59
                    your saying go w/4050's? what do you mean step up? start with small props and work from there? what would that max out at w/6s
                    • Maciek74
                      • 48
                      yep motors will be cheaper but in this sport 6s is nothing special, and sooner or later U will have to upgrade ESC's too, thats why i think changing ESCs is better, especially when u have 2 unused for resell right now
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        @ Matt by stepping up I mean larger props or pitched props for more speed and more headache lol. 4050's are plenty big for that hull and someone new to electric boats. You can easy get in the 90's with that setup (based on the power) but before you get there, have some fun and drive casualy.
                        @ Maciek, I don't get the part about 6s being nothing special? You can get 115mph+ out of 6s so why not special. No point of spending too much on ESC's at this point, as there is still a chance they could be used incorrectly and blow. Yes eventually a set of nice ESC's but believe me, the 180's can take a lot more then many would think. In this case here cheap don't equal bad! I would be happy to part with a set of 25035's MGM at $900 but why at this stage?
                        • iridebikes247
                          • 1669
                          the t180s are amazing escs for the money, no question. Kent and I have run leopard 4082 1600kv with seakings right kent? Anyway I was getting mid 70s in a less than efficient hull and the temperatures were always under 100 degrees. 8s is just overkill per side. Keep her light you'll be rewarded in the turns. Heavy means harder crashes and more drama when things go wrong. There are quite a few build threads for this boat I'd stick with proven setups people have gone well over 100 mph with t180 escs, if you have doubts just add a mean cap bank
                          • Maciek74
                            • 48
                            ofc u both are right, so far i have 3 seakings 180, burned first one pretty easy together with leo3674'1900, repaired for 10$ and still works nice on 4s :) , but according to my small (compaired to Yours) experience, now i would have bought bigger ESC's, cause now on Genesis Offshore 6S x442 and leo 4082'1600 iam hitting 200A very often, but i suppose on 2 engines it splits differently... :)
                            • Mattyb1975wahoo
                              • Sep 2013
                              • 59
                              the cap bank idea has been looking good to me regardless. I do car and home audio and I am schooled in the way of capacitance. moy importente lol.
                              I have been looking ( http://www.offshoreelectrics.com/pro...p8mm-2&cat=136 ) any thoughts? I thought if I ran 4 3s packs doing 6s then parallel the packs I could save money while using in my cars, distribute weight, as well as getting longer run time
