MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #46
    LOL Thank you.. Less talking dont you have work to do ??? LOL
    • bruiser77
      • 241
      #47
      I'm only allowed to post bullspit on threads other than my own! Lol
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #48
        Lol me too!!!
        • Chrisg81983
          • Jul 2011
          • 1556
          #49
          Nata looks great man I wish you luck with the build
          • Remmie81
            • Apr 2012
            • 134
            #50
            Nata,
            I like the design of your motor mounts, but (forgive me) I do not understand the idea behind it.
            Why double on the front?
              • 7651
              #51
              Kent,how big are the Lehners compared to the 1717's? Just curious. Looks like a good mount setup.
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                #52
                Originally posted by Remmie81 View Post
                Nata,
                Remmie,
                The idea serves a couple of things. I have learned my lessons from the past. Let me explain. Soon as you leave room for the wind up (3mm) the stingers just sit there and hold the shaft in place. All the preasure/load is on the bearings of the motors and the mount itself holding the motors, making it very easy to break if you have a crash or hit something in the water. The purpose of this setup is, the 2 mounts help each other and become double the strengh or more. instead of all the power be located on one 3.5mm mount its now in an area of 10mm (2x3.5mm plus gap) it also allows me to run extended bolts through the mounts and cover with epoxy (total area covered with epoxy will be close to 20mm) The mount will never give!!! Also, I'm saving the motors by having a thrust bearing on the second/front mount. that means the collet will push on the bearing of the mount and not the bearing of the motors.
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #53
                  I think the Lehners are on path with the 1717 but in a smaller package. If I understand right the Lehners will handle alot more RPM. They seem to be build like a brick and no wobly parts and loose bearings like the 1717's have. But power wise, I think its close. I will benefit from the RPM and the fact I can run both 5s-(6s HOT) and 8s just by swopping leads.
                  The lehners are slightly thinner but a bit longer 1/2" or so
                  • Prop-a-Gator
                    • Feb 2012
                    • 163
                    #54
                    Unique motor mount design. Sounds like you are going for bullet proof-ness. Any chance you'll put some fillets in those inside corners? Sharp inside corners are stress risers, but it seems no one bothers rounding them on these motor mounts - not that I've ever heard of one breaking.
                    The hull makes those Lehners look tiny. I would've needed a roof rack or a trailer to get it home! This will be an awesome build.
                    Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #55
                      HEHE,
                      Not going bullet prof, but want to make sure motors stay in place and not move. You just never know what might happen. Its not going to harm making it stronger. Your quite right, the Lehners look so small. Its amazing they have enough power to push the hull 90+mph (not saying thats what I will do) but the power is there on the right setup. I will definetly do my best to make everything line up and make everything run as smooth as I can. Measure twice, make a template then test and install.
                      • Remmie81
                        • Apr 2012
                        • 134
                        #56
                        Thanks for the explanation.
                        I think its a perfect solution!!!
                        Grtz Remmie
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          #57
                          Thank you Remmie, I hope it will work in my favor. The whole idea is to make an even better build than the 114. The last thing I want is parts flying off or misfailure because of me. I run in a small lake with people around. It's better to take precaution and make it right.
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #58
                            Ok,
                            Been spending some time on the drawing board. Here are the Carbon parts.
                            • jkr
                              FE Addiction
                              • 568
                              #59
                              Nice job.
                                • 7651
                                #60
                                That'll look cool in there bud.
