MHZ Mystic 1380mm build
  • bruiser77
    • 257
    It does the same thing, just a clean and removable external antenna mount that will extend the range. A must for carbon hulls.
      So how does it work with a co axial cable/antenna wire?
      • bruiser77
        • 257
        It's got a washer with a eye to attach the rx antenna to the external antenna lower shaft that attaches to the hull.
        • Espresso
          • Jul 2011
          • 248
          So your Rx wire itself remains in the hull or is it threaded through the loops on this MHZ antenna?
          • bruiser77
            • 257
            The rx wire stays in the hull and the external antenna with the loops is what is removable after running/storage.
            • numse1964
              • Oct 2010
              • 37
              Hi
              Do you use this kind of antenna with a 2,4 ghz radio ?
              - I thought that was a bad idear.
              I use this with my 40 mhz radio. And it's realy good and comfy.
              Best regards Henrik
              • bruiser77
                • 257
                I hope it works with 2.4, thats what im going to use it with. we shall see.
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  I love the idea of a removable antenna, can someone confirm it works with 2.4ghz?..... Maybe I can get an extra long antenna and win the "INCH" game over bruiser LOL 2" short damn LOL
                    What are you guys comparing now...
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      Hey Shawn, stick to the subject LOL - the thread here is My new "big" boat! LOL, dont destract bruiser, he's got work to do!
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        Ok, back to the real world again. Just looking at propshop's site. where would you guys start?
                        I'm going to give up on the traditional x447 for a hull this size.
                        5017/2 - 5517/2 or in the 60's ?
                        I think I'm hooked on the 8s setup motor is around 1380kv in wye mode
                        • bruiser77
                          • 257
                          With that size boat you probably wanna run a 442 at max!!!!! LOL! I'm so distRacted now! LOL!
                            I would think something in the 55 range should be appropriate.Should have some choices there.Fightercat has 5518's
                            Mind you with 1380kv on 8s that is some RPM.50's or 52's then.
                              Originally posted by nata2run View Post
                              Hmmm you should have known what was on my mind and told me yesterday lol
                              Man, I really like those. I couldn't figure out, do they have ball bearings installed?
                              So do these have bearings?I'm still aquiring information for my winters build.It may have gotton bigger now.
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                I would ever only build what I can fit on the back seat LOL. RPM wise I'll be in the 37k on 8s so it should pull a 50' something prop. 140km/h would be nice.
