MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #31
    I think the Doc has some 5518/3 from propshop, wonder if I can pull them safely. Potential to hit 100mph with something like that! That's if the lehners can handle it. Few more days and hull should be here.
    • Chrisg81983
      • Jul 2011
      • 1585
      #32
      Can't wait to see this
      I bought the Hpr drives by the way they should shpi out monday thanks for the help
      Chris g
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #33
        Congrats on getting the HPR, I was a 1/1000's of an inch from getting the 135 HPR!!! MHZ gave me a deal I couldnt refuse so I ended up with that. Hanspeter has some amazing Hulls though. and I always enjoy watching them getting build :) Kinda glad I got the MHZ though, just look at Christians new turbine powered monster! "so I keep telling myself anyway"
        Would be good to follow your build threat, all the best of luck. (although luck is for the unprepared)
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          #34
          Hull should arrive tomorrow or the day after, really looking forward to this one. Hopefully everything is in one piece.
          • Eric Ho
            • Jan 2012
            • 15
            #35
            Those are nice, but they dont ship to the US.
            • liteumup69
              • May 2011
              • 156
              #36
              Sure they do, I just got a set of there professional line couplers in the mail today, 8mm by 6.35 or 1/4 flrex
              • Eric Ho
                • Jan 2012
                • 15
                #37
                Ah, I guess he's selective then - this is the reply I got when I tried to order the drives:
                I don`t send this parts in USA. Sorry.
                I transfers your Money back.
                Mit besten Grüßen / best regards
                Jochen Preugschat
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #38
                  HOHOHO, HULL is here .... In my car
                  • Chrisg81983
                    • Jul 2011
                    • 1585
                    #39
                    Pics please
                      C'mon open it!!!
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #41
                        OK, She's here!!!
                        Thought I'd share the first photos. Looks smaller in the picture but shes quite big compared. (maybe because the 114 sits higher on the stand) This should be alot of fun.
                        Also ordered some carbon 3.5mm sheets, that I will be using + servo arms that I will be polishing chrome. I think I will go back to the traditional motor mounts as I want to use the 8mm thrust bearings. How ever, there will be 2 mounts per side on the front. Sorta like the honey combe design but without the combe. first mount will have the 14mm center hole for the motor bearing half way through, the second just the 8mm for the shaft. then a 0.5mm aluminium plate, for the thrust bearing. Both mounts will screw togeter with a 4mm spacer. So it will look like the honey combe but instead 7mm of carbon. It will then have the lehner bracket for the back support.
                        • Remmie81
                          • Apr 2012
                          • 134
                          #42
                          Looking nice!!!
                          I will follow this build!
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #43
                            Thank you Remmie, will follow yours too
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #44
                              Ok Guys,
                              to better understand what I'm planning to do with the mounts here is a little drawing. So 2 mounts for the front bonded with spacers. 1 mount for the back from Lehner. (will make a back bracket so it can screw on and come off anytime.
                              • bruiser77
                                • 257
                                #45
                                Congrats Nata! Welcome to the 50+ club:) AKA just for men! Lol
