MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #271
    Oh man what was I thinking, should just stick to what I know works. Again I don't know what possessed me to do it this way. If it don't work this time it will be a long and tough fix (I'm only saying that because I want it to look good.)
    • Remmie81
      • Apr 2012
      • 134
      #272
      Kent,
      I dont know either what (or maybe WHO) possessed you , always blame someone else
      haha
      no serious, you should be able to make the modification pretty easy I think?
      from the bottom drill out the current pipe, then you should be able to grind away the rest of whats left on the innerside pretty quickly.
      (unless youre nice carbon wrapped stuffing tube is in the way?)
      @Srislash,
      Thanks
      @Wayne,
      4mm should be sufficient for our electric boats as the speeds we drive are higher then the V-hull and therefore more water will flow.
      The 5mm are used as the V-hull will have a twin gas engine in it were every water pickup will be splitted
      (2 going to the pipes and 2 to the cylinders)
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #273
        Hey, there is still the chance that it works the way it is? That way no need to drill, grind or anything like that. In fact if it works the only mod will be the sound of 8s hehe.
        • Remmie81
          • Apr 2012
          • 134
          #274
          Yes youre right, first test before modifying stuff. Think I was to much thinking in the solving part haha.
          I really hope that it will work, saves you a lot of work.
          I will keep my fingers crossed for youre next run!
          • drwayne
            • 3012
            #275
            @Remmie.
            As a rule, petrol boats dont interest me.
            But twin anything and Im interested !
            nice work.
            Has it run ?
            W
            • ManuelW
              • Oct 2010
              • 786
              #276
              For the hot motors:
              Don't forget that this is also quite a fast setup and you ran a lot of partial throttle. The 2250's are quite small in size compared to the size of the boat. If some of your friends have one, try a pair of Octura X450/3 S&B.
              Less partial throttle will keep the motors cooler and with higher speeds you'll also get higher cooling flow.
              regards,
              Manuel
                Actually we were having a discussion over at Fightercat about the German motors.Are these ones 2 pole Kent?If so they are good for 80,000 RPM?
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #278
                  I think most Lehner's are 2pole
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #279
                    Originally posted by ManuelW View Post
                    For the hot motors:
                    regards,
                    Manuel
                    Hi Manuel, good to see you here..... please keep in mind that they were only pushed by 6s1p per side, so not 8s as I planned. I do have a set of x450/3 should it be that bad to run the 4818/3 ??? I honestly have to blame the cooling!! I didnt see any water exiting at 30-40km/h so still working on those pickups.
                    • Chrisg81983
                      • Jul 2011
                      • 1585
                      #280
                      Kent I might have 2 sets of counter rotating 450/3 if so I will just send you the extra set I have they are s&b by Dasboata well at least 1 set i know is done by him don't worry about money
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #281
                        Nooo dude, I cant do that!!! I have a set, S/B but you never know if you might need them. As your building that awsome boat you may run those props yourself. It's early days... "I lost shaft on the maiden" incl. the prop. would have been nice to have a spare set at that time.
                        Hang on to them for a bit, you might need them, BUT THANK YOU for the offer!!!!
                          So you may be able to go to 10s even from what we were discussing on FC.Got no idea the amp draw then though.And what props to use.Your 45's maybe?
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #283
                            Hehe, I'm no RPM freak, nor would I stand near a motor doing 80K Rpm unless its a turbine :) I don't know why you would push it that hard though. I think a 50 ish prop is a nice size in the low 40k just play with pitch. 8s is the max im going to run on my 2250's that's around 40k - I have cooling issues remember LOL and here you are talking 80k RPM, what's wrong with you LOL
                            • Prop-a-Gator
                              • Feb 2012
                              • 168
                              #284
                              . how many things have to be absolutely perfectly balanced at that rpm? Do they have unobtainium bearings? Who runs 80k rpm? I just want to here that.
                              Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                #285
                                I think .... like a car tire expands at speed so will the prop at 80k RPM LOL even if I used a 45mm prop it'll come back 50mm LOL LOL
                                unobtainium hmm how did you know
