MHZ Mystic 1380mm build
  • jcald2000
    • 786
    #121
    Can't use regular heat skrink for epoxy it won't release.
      But it would sand off real easy.Great plan BTW Kent.
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #123
        Not the most fun I had, but here is one sorta done. May buff abit when epoxy sets off completely.
        • drwayne
          • 3012
          #124
          Kent
          A friend in Salisbury(5Kms away ) has CF in tubular sock format... woulda been easier than wrapping the cf matt..
          W
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #125
            What bendable? Cf tube. Like the stock battery mounts, I like making my own
            • drwayne
              • 3012
              #126
              a long rolled up length of cf formed as a sock.. cf cloth.. woven into tubular shape.. soft, sock like, bendable,foldable, cuddly .. like pipe braiding.
              neva mind.. too late now.
              Hmm.. have chosen power for mine.. Sphincter factor 9.5 .... 12S to 5698/910 ..
              zoom zoom
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1876
                #127
                zoom zoom
                MAN....always the hard way for me LOL
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #128
                  Hello, got the support mounts for the main carbon plate glued in there is 12 of them, also did some buffing on the stuffing tubes. Next will be the under hull water intakes.
                    So carbony,so carbony
                    • drwayne
                      • 3012
                      #130
                      haha he'd soil his pants if they created carbon eating nanobots to lower the global carbon problems !!!!
                      It does look darn pretty, though .....
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #131
                        Hello guys,
                        Got a few things done. drilled holes for the rudder, installed water pickups (still need to cut the teardrop) glued/waterproofed the drivers.
                        little luck will be on the lake in no time.
                        • Chrisg81983
                          • Jul 2011
                          • 1585
                          #132
                          Lookin good
                          • drwayne
                            • 3012
                            #133
                            Apologies upfront . you do know lots.. however, the pix suggest the water pickup tube leans fwd, making in a drain ?
                            More pics could offer clarity..
                            Luv ya work.
                            W
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #134
                              Luv ya work.
                              W
                              Maybe drain is a good idea when I fill up with water :). I have now dremmeled the teardrop shape into the hull. Illustration shows the configuration of the jets & cut.
                              regarding leaning forward....well regardless, thats the way the hoses will go anyway. Will see in the pond how good it works, but I'm glad I got them that close to the tunnel.
                              • Chrisg81983
                                • Jul 2011
                                • 1585
                                #135
                                Once that teardrop is filed out they look like they will be perfect looks great keep up the nice work
