First build... Cheap boat, lots of power
    • 7651
    #1366
    Originally posted by seehuusen View Post
    wow! That's a really nice looking boat! Well done! Will this get it's own thread? I wanna see this build!! :D
    Sorry I missed this, I do have a thread going for this but perhaps I should do a ne "build thread" as it is a conversion and perhaps someone will have suggestions for some of my changes.
      • 7651
      #1367
      Originally posted by masonis1 View Post
      Well I have yet to fix my flex, I don't have a tool small enough to remove the set screw and now the flex is starting to get hard to turn. Not good, not sure how I'm going to remove this...
      What collet do you have on there Mason,some of the octura's have a funny size and none of my allen key sets have it. My LHS does have them though and I could grab one for you at my next convenience(no idea when)
      • masonis1
        If you cant control it 👍👍
        • 1173
        #1368
        I'm not very sure, it's the drive dog that came with the flex that was given to me for the build. I think he said it came off a genesis
        When speed isnt the option, change your ways
          • 7651
          #1369
          Do you not have a 1.5mm allen key?
            • 7651
            #1370
            Theze would be good Mason http://www.homedepot.ca/product/26-p...all-end/966661 Or there are smaller kits.I have a couple of Stanley sets.
            • masonis1
              • 1173
              #1371
              I might check them out. I don't have a 1.5
                • 7651
                #1372
                It should be a 1.5. My FC ones are 2mm.
                • masonis1
                  • 1173
                  #1373
                  I'll take a look but the screw is messed up from I guess rubbing on rocks or something
                  • seehuusen
                    • Apr 2012
                    • 96
                    #1374
                    Would be nice to see the boat built srislash :)
                    I just ran my Musculus on 4S! Very fast now! But I think I might be able to squeeze a little more out of it with some trimming and a slightly larger prop :D No heat problems either
                    • masonis1
                      • 1173
                      #1375
                      The boat hulls on 4s I bet
                      • seehuusen
                        • Apr 2012
                        • 96
                        #1376
                        it's quick! As in, I'm comfortable running the boat on 3S flat stick from the minute it hits the water until the cut off takes over... But on 4S, it's required to slow down on anything more than a slight turn!
                        I've been looking at more prop options, thinking about the 37mm 1.4p I've got, I will need to get something a bit bigger looking at a 40mm 1.4 prop, but I still need to try out the 35mm 1.7 light weight prop I got off HK... I'm spoilt for choices LOL
                        • masonis1
                          • 1173
                          #1377
                          Why does the cutoff go on so early
                          • seehuusen
                            • Apr 2012
                            • 96
                            #1378
                            it doesn't in my case, I was just saying it runs flat stick on 3s without feeling maxed out...
                            If you have problems with it, try adjusting your ESC :)
                            • masonis1
                              • 1173
                              #1379
                              Oh I was wondering what you were saying about your cutoff. Never mind hah. But on mine 3s is a lot of power.
                              • seehuusen
                                • Apr 2012
                                • 96
                                #1380
                                what was your KV rating again?
                                Mine is a 2500KV, so perhaps the difference is that?
                                3S = 27750rpm
                                4S = 37000rpm
                                I'm upping the prop diameter now!
                                I also think I have a fair bit of slippage, I need to try out a 3 blade prop, with the same diameter and pitch as my current prop... But they are not in stock currently...
