First build... Cheap boat, lots of power
  • Chrisg81983
    • Jul 2011
    • 1556
    #1216
    ImageUploadedByTapatalk1336426367.975528.jpgImageUploadedByTapatalk1336426385.023006.jpg
    • masonis1
      If you cant control it 👍👍
      • 1173
      #1217
      Thanks again. Ill go home and fix that tonight.
      When speed isnt the option, change your ways
      • Chrisg81983
        • Jul 2011
        • 1556
        #1218
        Hey no problem if u can't read it that good let me know I will email them to you
        • masonis1
          • 1173
          #1219
          Ok cool.
          • masonis1
            • 1173
            #1220
            Bent the link and reversed the steering.
            • masonis1
              • 1173
              #1221
              Also did the strut adjustment. It was about 1.5 cm higher than the bottom of the hull. Now its flat.
              • masonis1
                • 1173
                #1222
                Forgot this.
                  • 7651
                  #1223
                  That should be better.
                  • masonis1
                    • 1173
                    #1224
                    I think so. I also moved the rod up a tab on the horn to get more steering and i moved my epa on my transmitter down. Ill mess with that my next run. I wish the forecast was clear and sunny but.. its dark, rainy, and windy....
                    • masonis1
                      • 1173
                      #1225
                      so, i'll test this setup and see how it works asap
                      • masonis1
                        • 1173
                        #1226
                        So the raising of the strut, what should i expect from that change?
                        • masonis1
                          • 1173
                          #1227
                          Hey, i have an only xbox 360 that is broken, its all tore down. I notice everytime i see it, it has around 50 caps on it. Could i take some off and put on my esc to make it better?
                          • izcain
                            • Mar 2012
                            • 274
                            #1228
                            raising the strut should make the boat smooth out!
                            CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
                            • masonis1
                              • 1173
                              #1229
                              Oh cool.
                                • 7651
                                #1230
                                If this statement is true your adjustment will have that prop biting better on takeoff.We'll see what it'll do to everything else.
