Haha sounds good... At first, i just wanted to beat my cousins blast. Now its to surpase it by a LOT
First build... Cheap boat, lots of power
Here's what your actual motor can looks like in the yellowAttached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Here's a vid of one of my "toy" conversions of the Syma from the same company as your Balaenoptera..........same size motor on 4s and a smallish prop.........could go larger. Its faster than it looks on that large lake..............
Yours is 23" compared to mine at 27"............and yours has a little more width so it should ride "up" a bit more................yours will be faster.Originally posted by masonis1 View PostThat looks fast as hell. Should i be able to get that speed?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
It'll sit up on the surface more. If you set it up right...............weight, balance/'COG, prop etc............ you should get 35 mph out of it. You'll actually reach the hull's limit before you run out of power.........NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
