First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1173
    #316
    I dont know ANY%ING about props
    When speed isnt the option, change your ways
    • masonis1
      • 1173
      #317
      Oh and happy easter
        • 7651
        #318
        Originally posted by h2o 1 View Post
        I dont have any 35mm's.The smallest i have is 32mm 1/8 shaft.
        I have a aluminum 30,and an old 35.But herein lies another problem,might need a stepped down shaft.I have a spare Proboat plastic prop 40mm.I haven't got anything in the 37-38 range yet. M-a-W should have an idea as he has a couple of these motors so should know what they will push.
        Happy Easter eggs to you's as well.
        • masonis1
          • 1173
          #319
          What do you mean by the numbers
            • 7651
            #320
            Sorry Mason,The numbers change around a bit but for Octura props they will call it X 430.That is 4=1.4 pitch or 1.4 x diameter.And the 30 will be that diameter of the prop.Other's will list as 4518(such as ABC props)which will be 45 mm diameter and 1.8 pitch.As you increase pitch you are usually increasing speed but lose a little off the start.More pitch also increases amp draw. Questions?
            • masonis1
              • 1173
              #321
              Yes. How can i know which pitch to get?
                • 7651
                #322
                That is when the experimental game starts.Just get the boat going and go from there.Someone on here should hold a two year course on props.I don't know if anyone is a master.
                You will probably start with a 1.4 prop.
                • masonis1
                  • 1173
                  #323
                  Ok i might have a 1.4 plastic. Whats the advantages from plastic to aluminum or brass?
                    • 7651
                    #324
                    Plastic will flex and flatten out and even blow apart when you start juicin them up(RPM). Aluminum can as well.Beryillium and stainless do not.
                    • masonis1
                      • 1173
                      #325
                      Ok now i know
                        • 7651
                        #326
                        Some of the guys experiment with plastic to get a rough idea then buy a good one as plastic is cheap and a good "done" prop is $35 or more.
                        • masonis1
                          • 1173
                          #327
                          Alright sounds good. I have like 4 different props i can tryout then i can get a metal one or something.
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            #328
                            You ever figure out what size diameter your shaft is?
                            • masonis1
                              • 1173
                              #329
                              5mm
                              • Make-a-Wake
                                FE Rules!
                                • 5554
                                #330
                                For your flexshaft?
