Thanks, I had the stickers this afternon, very good job, incredible quality
MMProducts 39" Deep Vee
Here is the last clear decals sheet. I' m waiting for small air intakes and let' s go. I always star with paint/stickers job.
Hey man i am really thinking of building this boat. With the set-up you have what speeds do you think you are going to get? Also what Motor would you recommend since the one you are using is discontinued?
And what offset rudder did you use? Do you really need two??
Would you recommend this boat to a first time builder???
GREAT BUILD!!
I think 80 to 100 km/h I won' t paint the Rapid only clor decal sheets and stickers
Here is the master for windows cockpit. Adjust the scale 26 cm x 18 cm, print and have fun!
Do you know those propeller from Promise Hobby? They are cheap, 20 Euros each. Without talking of the price those props look perfect excellent, they are light, well manufactured . The blades are thicker than Tenschock' s. Just have three-bladed , one of 48mm and l' other made 52mm. The step is of 1,4 for both. This is the right size, Octura X447/3 is recommanded with a CC1717 xith 6S in a 1 meter deep vee . Anyway this is a very good deal, props need to be sharpened, no more
Edit ; those props are made by VXP Propellers and price is 50% down at lzrc. Have a look :
No update, I was skiing for 2 weeks in French and Swiss Alps
I always start with a finished and clean hull
Hey Alfa, mine turned up, the quality of the hull is amazing. I wont be painting mine!
Ive got a 5682 1700KV i was going to run with 5 S packs, but i am starting to think its going to be too big! the weight distribution will be very diffcult with a motor this size. have you got any plans for yours? ive allready got a 3/16 drive setup and stinger drive, no rudder yet.
Oh yes, the Rapid or Racemaster are very nice, the materials and finish are very high quality, I don' t paint mine. I use vinyl adhesive color sheets for places and stickers for an Outerlimits replica. A Leopard 5692 is very big and heavy, 880 grammes, my Castle Creations 1717 is 560 grammes. If you want to use the Leopard 5692 this is not a problem, heavy motor adds stability for the hull you can use 3S + 2S batteries, 3S on the left side. I use 2 rudders, found a model xhich can be reversed to have a symetrical mount
IMPORTANT: The motor must be installed on the back of the hull
If you are interested I sale this set of stickers and I have stickers for cockpit, let me know if you need oneAttached FilesLast edited by Alfa Spirit; 03-22-2012, 03:47 PM.
