MMProducts 39" Deep Vee
  • Rumdog
    • 6453
    #61
    I might answer your question if you answer mine. I'd probably still be hesitant though since I don't think you're actually going to build this boat. All your build threads ever are, are pics of your gear nicely posed by the hull. They seem to move backward if anything, and you've never finished a build. What gives? Don't they have epoxy in France?
    • Alfa Spirit
      • 2131
      #62
      What is minimum distance between the blades?
      If the blades are too much spaced this is not nice, 80mm between the rudders looks nice with the design of the deep vee
      Max diameter for ptopellers will be 50mm
      • Rumdog
        • 6453
        #63
        I feel like I'm taking crazy pills..
        • Alfa Spirit
          • 2131
          #64
          I was talking with people frim MMP and looked to Rapid and Racemaster builds on forums, the motor must be placed near the back of the hull. This is the best choice for stability, and especially if thee motor is big like the CC1717
          Distance between back hull to motor = 20cm to 25cm. More and hull will dancing when you turn
          • Alfa Spirit
            • 2131
            #65
            custom cockpit window decal
            • iamandrew
              • 574
              #66
              I think im gonna need a smaller motor in mine. i just realised that its going to be very hard to get the collet off AND no room for the steering servo with the TP5682
              • Alfa Spirit
                • 2131
                #67
                I don' t think you need a smaller motor have a look here (Turnigy 5692) http://forums.offshoreelectrics.com/...cemaster-build
                How many kV is your Leopard motor 1360KV or 1670KV?
                • iamandrew
                  • 574
                  #68
                  Ive got a spare 1700KV turnigy 5682 with the backet and the cooling jacket
                  Ill put it in the hull and show yas. I wasnt sure how far back it owuld have to go. if its only 15CM from the back then its not much stuffing tube either
                  • Alfa Spirit
                    • 2131
                    #69
                    I edit the reply, not 15 but 25cm,
                    • Alfa Spirit
                      • 2131
                      #70
                      I made a decal sheet with offical OSG Racing sponsors. Did I forget something?
                      • Alfa Spirit
                        • 2131
                        #71
                        • Rumdog
                          • 6453
                          #72
                          Still nothing mounted...
                          What are you waiting for?
                          • Alfa Spirit
                            • 2131
                            #73
                            Good boy...
                            • Alfa Spirit
                              • 2131
                              #74
                              I made a decal sheet with offical OSG Outerlimits Racing sponsors.
                              • Rumdog
                                • 6453
                                #75
                                You forgot that you posted this exact thing earlier... then deleted it, and posted it again.
                                Cute stickers. How fast will they make your boat go?
