MMProducts 39" Deep Vee
  • Alfa Spirit
    • 2131
    Here is the hull with its hardware, this boat don' t need flaps and turnfins. The motor is a CC1717 1580kV the Speedmaster strut from OSE is perfect with twin rudders and motor mount is made by Hervé http://www.mini-meca-rc.fr/ . Flexshaft is a Prestwich Model boats, I hope it' s strong enough This hull is awesome
  • iamandrew
    • 574
    Ill have one soon :D
    Ill be giving a 1700 5682 Turnigy a try in it on 5S with a 3/16 shaft.
    hope the packs fit!
    • Alfa Spirit
      • 2131
      I won' t paint the Rapid hull the finish is very high quality. So I made 3 sheets of stickers to print on transparent or white vinyl, I' m not sure which one is the best, may be white for better colors? Price is good: 30 €uros/38 US$ for the three sheets. What vinyl? tranparent or white?
        • 7651
        Those look great Alpha,I think I may need some.I've been keeping an eye open for sponsor decals.So are you selling these on clear vinyl?
        • Norman2
          • Sep 2008
          • 321
          Hi Clear Vinyl will be best. When are they going to be Available? Regards
          Norman2
          34" Ekos Cat UL-1 Powered
          • Alfa Spirit
            • 2131
            I just put an order for one set transparent outside quality. If I need to put a sticker on a dark part it' s possible to put the sticker on a white vinyl.
            • cugino
              • 136
              Racemaster is very popular hull in my country.
              Most of us have Leopar 4082 or Castle 1520 1600KV with 6S 5000mAh akupack. We are very happy with this setap, Racemaster drives well with X447.
              -= MHZ Shockwave - MHZ Micro Fountain - MHZ Cougar 2 - "Orange cat" =-
              http://olaf.webz.cz
              • Alfa Spirit
                • 2131
                This is cool, I'll run the deep vee with a Castle Creations 1717 motor, same range with Leopard 4082. This motor is now discontinued. 4 pole motor, 1580kV, Motor diameter is 50mm, The CC1717 is 85mm long and the weight? 570 grammes...
                Are you running with 6S 1P or 6S 2P parallel wiring. What do you think using 3S packs?
                Here is rhe monster
                • Rumdog
                  • 6453
                  You're going to want 6s2p with that motor. It's a hog.
                  • Rumdog
                    • 6453
                    I thought you bought the MHZ Racemaster????? http://forums.offshoreelectrics.com/...ter&highlight=
                    "With 2 rudders it' s easier to adjust the trajectory, flaps will help too. I hate turnfins I hope I won' t need those parts
                    Using two 6S packs will help me to find the right balance, what do you think??
                    I did it, I put an order for a white Racemaster and I will sell my MHZ Fountain Dragon Lady, like new, untouched, undrilled. I prefer the Racemaster, those two deep vee' s have the same lenght, same V design."
                    • Alfa Spirit
                      • 2131
                      In fact I wanted to buy a Racemaster and I bought a MHZ Lady Electro Fountain
                      • Make-a-Wake
                        FE Rules!
                        • 5554
                        You ever gonna build one an run it................maybe show us some vid?
                        • Rumdog
                          • 6453
                          HUH? http://forums.offshoreelectrics.com/...ide&highlight=
                          I'm really confused here..
                          • 6BOOST
                            • Sep 2011
                            • 286
                            Lol, I know your confusion Rummy, he's saying originally he wanted to get the MHZ Racemaster, but ended up getting a Fountain, an now rather than following through with his order for the MHZ hull he has purchased a Rapid (exact same boat) direct from MMP, even tho he said he placed the order for the racemaster
                            6BOOST
                            6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
                            • Rumdog
                              • 6453
                              Don't forget.... sold the Fountain.
