the hobbyking ones come with extra caps too?
it should be set to autodetect, most people disable the BEC (pull the red wire on the RX plug) when running 6S
Are ya talkin the red one in the mid of the black and white,Are you posative I should do that bud,
Chud not sure what your saying your going to do to the boat.
120grit to wet sand after final coat is applied? Def not!!
I thought if I wet sand after first or second basscoat of white ,It would be slick ,then apply the decal;s,then three coats of high car gloss,but your right ,lightly sand if ya want to apply more clear coats after a day or two
Chud, you might be thinking about 1200 grit wet sand paper. I usually scuff gell coat with 600 grit. Them primer and wet sand with 1000 grit. Then primer again and wet sand with 1200. I shoot with water based paint then just use Duplicoler clear coat from the auto parts store. Comes out very smooth and no need to wet sand the clear.
Well bud's everything turned out good ,First I blue taped the hull to make sure no paint gets in the hull,and make sure you also tape the little hole's inside too.Than I wet sand it with 220 vary fine sandpapper,Than I only used one can of interior/exterior flat white,
And As you look I only did the top side,just below the nasty brown line,Know when jeff's cool kicka$$ decal's arrive I'll be ready.
Also I pulled the red wirer out of the rx plug ,in my new t180 ,I'll be running two 6s 30c 22.2v 5000mah,Thank's for lookin out guy's
Rattle can paint it thicker and therefore more forgiving. With the thin water based paints I have been using the hull needs to be baby but smooth or the paint will not fill the imperfections that wouldn't show with rattle can paint.
If you haven't done so yet, scuff the bottom of the hull in a front to back (or back to front) motion to help it break plane easier.
Nice job bro,, ill get those plugs made up for ya asap!!! Remember if you remove the power wire from the esc youll need a seperate power source like the one in my twin hull,, you can get them from RadioShack and well need to put a plug on it to hook to your RX,,,
Jackblack that blue dose look sweet nice job painting it!!!! Your sons going to be the man on the water with that one!!
