chuds DF33 from OSE
  • fastblack
    • 119
    #31
    x642 is good if you want both speed and good runtime x442 is also great =) i think x645 at 6 cell will shorten runtime a bit.. because of high amp draw
    • Jurjen Olthoff
      • Jun 2011
      • 2
      #32
      Allright, thanks for the fast reply! Ofcourse we can't expect hours of running on nearly 2000 Watts ;-)
      • Rich
        • 581
        #33
        Fastblack, what rudder are you using? I am thinking I might also do a flooded stuffing tube on this as well.
        • CHUD
          • 554
          #34
          Hay bud,s I,m back just got my ul,1 motor sold and gettin ready too place the order for the 4074 1400kv from ose,but I need to know if I can still use my motor mount from the 3656 and do I have to remove the rail,s,
          • Rich
            • 581
            #35
            That will depend on the water jacket. I would measure it and see if you will have space in-between the rails. I am sure that mount will have the same mounting hole spacing as the 4074, it look like the same mount I have for my 4082...
            • CHUD
              • 554
              #36
              Rich in,between the rails 53mm ,totale for the hole 27mm
              • Rich
                • 581
                #37
                I just measured my water jacket and its right around 48-49 mm so you have plenty of room, as for the hole spacing you are in the clear! Go for it!
                • Rumdog
                  • 6667
                  #38
                  Dude! Get the 4082 for a few more bucks! It is more suited for this size hull and will spin up some bigger props. You'll want at least a 45mm prop to push this boat efficiently on 6s.
                  • CHUD
                    • 554
                    #39
                    WOW RUMMY that hull is flyin,are ya sayin 4082 and 1400kv 0r1500 kv I only have 120 esc,and hay bud why don't thay make 4074 1400 in green
                    • Rich
                      • 581
                      #40
                      From my experience, this is worth the few extra bucks!
                      • CHUD
                        • 554
                        #41
                        Sound's good 4082 and 1500kv with45mm two bladded prop or 47 , now on the 6cell witch one 4000 30 cell or 5000 30cell ,what are you runin Rum
                        • obrien008
                          • Sep 2009
                          • 141
                          #42
                          Youll need atleast 5000mah, might need 2p, or maybe 2 4000 packs
                          • CHUD
                            • 554
                            #43
                            when you say 2p is that 2pack,s ,man I really need to no
                            • Rich
                              • 581
                              #44
                              Yes, its two packs wired in parallel.
                              • CHUD
                                • 554
                                #45
                                hay rich I;m gettin 4082 1550 for $108 and watercooler $21 I need to no what pack to look for at hobbyking is it 2packs// 3cell 5000 or4000 mah
                                to make 6cell
