chuds DF33 from OSE
  • monojeff
    • Nov 2010
    • 2551
    #76
    Chud not sure what your saying your going to do to the boat.
    120grit to wet sand after final coat is applied? Def not!!
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • CHUD
      • 497
      #77
      Originally posted by Boaterguy View Post
      the hobbyking ones come with extra caps too?
      it should be set to autodetect, most people disable the BEC (pull the red wire on the RX plug) when running 6S
      Are ya talkin the red one in the mid of the black and white,Are you posative I should do that bud,
      • CHUD
        • 497
        #78
        I thought if I wet sand after first or second basscoat of white ,It would be slick ,then apply the decal;s,then three coats of high car gloss,but your right ,lightly sand if ya want to apply more clear coats after a day or two
        • carlcisneros
          • Jan 2010
          • 1218
          #79
          Chud, PLEASE listen to ths guys here concerning the T180ESC.
          Most of us have alot of experiance with these litle jewels.
          There is great knowledge here and no one will steer you wrong.
          • monojeff
            • Nov 2010
            • 2551
            #80
            Here you go chud some reading.
            http://forums.offshoreelectrics.com/...0-on-6S-power&
            http://forums.offshoreelectrics.com/...aking-180A-ESC
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • monojeff
              • Nov 2010
              • 2551
              #81
              Is your boat not white gelcoat?
              Why would you want to paint it white again??
              150grit sandpaper is very course.
              Not meant for wet sanding thats for sure.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • JackBlack26
                • May 2007
                • 903
                #82
                Chud, you might be thinking about 1200 grit wet sand paper. I usually scuff gell coat with 600 grit. Them primer and wet sand with 1000 grit. Then primer again and wet sand with 1200. I shoot with water based paint then just use Duplicoler clear coat from the auto parts store. Comes out very smooth and no need to wet sand the clear.
                Here is a 26" price I just finished for my son.
                • CHUD
                  • 497
                  #83
                  It is white gelcoat jeff but it has a brown line all the way around the hull ,I dont know how to hide it,
                  • CHUD
                    • 497
                    #84
                    thanks for the info bud ,,love that blue,,
                    • CHUD
                      • 497
                      #85
                      Well bud's everything turned out good ,First I blue taped the hull to make sure no paint gets in the hull,and make sure you also tape the little hole's inside too.Than I wet sand it with 220 vary fine sandpapper,Than I only used one can of interior/exterior flat white,
                      And As you look I only did the top side,just below the nasty brown line,Know when jeff's cool kicka$$ decal's arrive I'll be ready.
                      Also I pulled the red wirer out of the rx plug ,in my new t180 ,I'll be running two 6s 30c 22.2v 5000mah,Thank's for lookin out guy's
                      • JackBlack26
                        • May 2007
                        • 903
                        #86
                        Thanks for the compliment on my son's boat. He picked the color.
                        Good job on your boat! That seam line would drive me nuts too. I would have to fill it smooth and paint like you did.
                        • CHUD
                          • 497
                          #87
                          Thank's bud,it was drivin me crazy,I used the only fine sand papper I had p220 and everything looks good,
                          • JackBlack26
                            • May 2007
                            • 903
                            #88
                            Rattle can paint it thicker and therefore more forgiving. With the thin water based paints I have been using the hull needs to be baby but smooth or the paint will not fill the imperfections that wouldn't show with rattle can paint.
                            If you haven't done so yet, scuff the bottom of the hull in a front to back (or back to front) motion to help it break plane easier.
                            • CHUD
                              • 497
                              #89
                              will do
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                #90
                                Nice job bro,, ill get those plugs made up for ya asap!!! Remember if you remove the power wire from the esc youll need a seperate power source like the one in my twin hull,, you can get them from RadioShack and well need to put a plug on it to hook to your RX,,,
                                Jackblack that blue dose look sweet nice job painting it!!!! Your sons going to be the man on the water with that one!!
