chuds DF33 from OSE
  • Rich
    • 551
    #46
    You want to run 6s?
    Edit: If so you want these http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
    The idea is to have two 6s 5000 mAh packs, wired in parallel (which is + to + and - to -) to give you 10000 mAh @ 22.2 volts (which is what a 6s pack is)
    24 R/C vehicles and still counting...What budget?
    • CHUD
      • 497
      #47
      Originally posted by Rich View Post
      You want to run 6s?
      HA/HA/HA That's the one I just looked at good deal thanks bud
      • Rich
        • 551
        #48
        No problem, paralleling packs is the best way IMO
        • obrien008
          • Sep 2009
          • 132
          #49
          Ya run 2p if you can, fyi
          http://www.hobbyking.com/hobbyking/s..._Inrunner.html
          Leopard motor for half price...
          • CHUD
            • 497
            #50
            I almost went with that motor bud, BUT last weekend when I watched my brother,s 37''genesie do 51 not tuned in and the way the Leopard 4074 2200 sound,s I was sold on that motor Just wish H/J would have let me vid it when I asked,I'm sure that someone will test the Turnigy out really soon,Thanks for lookin out obrion
            • obrien008
              • Sep 2009
              • 132
              #51
              The Leopard Motors are just rebranded Turingy's, the link I sent you is the same motor just a better color. Take a close comparison of the pictures.
              • monojeff
                • Nov 2010
                • 2551
                #52
                Chud I got your email and PM I will be working on your graphics in next day or two I hope.
                I will keep you posted.
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • CHUD
                  • 497
                  #53
                  Thank's Jeff you are the man, And just a heads up guy 's my motor it's on it's way 4082 1550kv
                  • CHUD
                    • 497
                    #54
                    Got my motor fast shippin 3day's Thanks OSE almost ready to put it in, But I think I need to order a ring to hold up the rear of the motor cheaked out ose does anyone sale just the back ring ,I want it to match the fighter cat one on the front
                    • CHUD
                      • 497
                      #55
                      I have got the motor in and put the water jacket on,but there's no room for the ring I just order from fightercat,I;s the motor going to be OK like this,I got two 6s 30c 5000 on the way should be here soon,
                      • obrien008
                        • Sep 2009
                        • 132
                        #56
                        Def put some sort of support below that motor if you can
                        • CHUD
                          • 497
                          #57
                          I'm kinda lost on this one bud should I tear everything out and stop my order at fighter cat and get somethink els
                          • JPriami
                            N4FOX
                            • 1675
                            #58
                            You can always make a holder for the back of the motor. I did this on my MG to hold up my 1518. I made the lower brace that mounts to hull and supports weight of motor out of plexiglass thats glassed to the hull. Then made a wire half loop that swings over the motor can to hold it to the mount. Unbolt one side and swing it open to take motor out after taking front motor mount loose.
                            • CHUD
                              • 497
                              #59
                              Way to go bud now that give me a idea
                              • Rumdog
                                • 6453
                                #60
                                Just make a small wood wedge. Like a doorstop shape and glue it in under the motor so it's snug against the can and the floor. Good to go.
