1/10 Scratch Built Thunderboat (Finlay Plans)
  • CHUD
    • 497
    #46
    cool jeff
    It's looking good jeff do you ever sleep
    • monojeff
      • Nov 2010
      • 2551
      #47
      Got all the foam sanded down using an orbital sander as well as all the triangle balsa. I also started to mock up the decking with some prints of the plans to see how things are going to line up before I start cutting it and gluing it down in case any adjustments needed to be made.
      Everything appears to line up pretty good.
      There is a little difference from the plans to how my edges came out but not much as you can see in the pictures where I marked the edge with a marker.
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • monojeff
        • Nov 2010
        • 2551
        #48
        I also checked to make sure the boat was level and even on the sponsons and transom before I start decking to make sure nothing needed to be tweaked so it will be straight once decked but everything looks good so I will start cutting the deck pieces and gluing them on soon.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • rcboatmanwithkids2880
          • 340
          #49
          Hi Jeff ,
          Looking good mate , currently i am building a Dumas .45 which i have just completed the frame work ....
          All the best with your hydro ,
          Brad
          Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
          • monojeff
            • Nov 2010
            • 2551
            #50
            Originally posted by rcboatmanwithkids2880 View Post
            Hi Jeff ,
            Brad
            Thanks Brad.
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • monojeff
              • Nov 2010
              • 2551
              #51
              Started working on the decking a few days ago.
              First thing I did was seal the bottom of all the pieces with 2 coats.
              Then I waited a day for things to dry and light sanded them then put another light coat on them then let that tack up before laying them over the framework.
              I also sanded to shape the front and rear hatch/cowl braces.
              I installed the front before the decking but left the back one out for now until I figure out where the best place is going to be for the cowling.
              I used a very generous amount of epoxy and cabosil mixture over everything then put on the decking and taped and held them in place with cloth pins while I put the other pieces on the same way. I then taped them all together and added weight to hold things in place.
              I used a half a roll of tape and a bunch of paint cans and a few misc tools.
              After checking and double checking to make sure things would fit nicely they were still a little off where the three pieces come together on the nose. Nothing I cant fix with a bit of sanding.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • JimClark
                • 5902
                #52
                Looks great Jeff
                Billy Graham
                • monojeff
                  • Nov 2010
                  • 2551
                  #53
                  Here is a few more pictures of the decking.
                  I am also starting to work on the engine, arm rests & steering wheel which I got from bardahlracing. He is also making me a cowl and driver which I will have soon. They are some very nice pieces and I will be painting them and adding some detail soon as I get some time to work on them.
                  Next step is a LOT of sanding to get the deck sides sanded down to size.
                  Then I will be cutting out part of bulkhead C & D as well as installing the rear stringers.
                  OSE GIFTING ELF
                  HAPPY HOLIDAYS!!
                  • monojeff
                    • Nov 2010
                    • 2551
                    #54
                    Originally posted by JimClark View Post
                    Looks great Jeff
                    Thanks Jim it came out pretty good for my first time doing something like this.
                    I am happy with the way everything is turning out, nice to see it taking some shape!
                    Next time I build a boat like this I will put tape on the inside of the deck bracing which will save a lot of sanding that will need to be done because of the epoxy coming out from under the decking.
                    You can see in the last photo I uploaded that there is a lot of cleaning/sanding to be done.
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • monojeff
                      • Nov 2010
                      • 2551
                      #55
                      I cut out the sections in bulkheads C & D per the plans.
                      After I did this I realized that the floor obviously needed some extra strength.
                      I glassed the entire floor and also the sides of the inside up to the deck seam to add some strength to everything.
                      Here is a photo & I will be posting more progress up tomorrow as I have a few more spots that need some glass added that I didn't get to last night.
                      I used 4oz cloth on this.
                      OSE GIFTING ELF
                      HAPPY HOLIDAYS!!
                      • monojeff
                        • Nov 2010
                        • 2551
                        #56
                        I hollowed out some of the pieces of the dummy motor.
                        Glad I went to the garage to do this as dust gets everywhere.
                        I was sure to wear goggles and a mask so I didn't get any in my eyes or breath it in.
                        I used a dremel and a grinding wheel got the job done pretty quickly and worked out well I think.
                        I slipped a bit on the middle one but should not be a problem I will just fill that spot in with some epoxy prior to assembly.
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • monojeff
                          • Nov 2010
                          • 2551
                          #57
                          Here are some pictures of the rear stringers and glass I added you can see it goes up the sides and over the deck seam to add some xtra strength along the joint.
                          I also mixed up some epoxy and cabosil to fill the area on the nose that wasn't quit flush. It will still need some more smoothing but I figured I could do it when I start to seal the deck. I wanted to make sure it wouldn't move around or break loose while I was sanding the decking flush with the sides.
                          OSE GIFTING ELF
                          HAPPY HOLIDAYS!!
                          • monojeff
                            • Nov 2010
                            • 2551
                            #58
                            I finished smoothing out the decking on the nose flush with the sides.
                            Now I just need to finish the back half and I will be ready to seal the deck.
                            Last picture is of some detail I added to the dummy motor valve covers with my dremel and a few small bits.
                            OSE GIFTING ELF
                            HAPPY HOLIDAYS!!
                            • monojeff
                              • Nov 2010
                              • 2551
                              #59
                              Here is a picture of the rear stringers installed.
                              All the decking is now sanded even with the hull.
                              As well as the rounded part behind the sponsons.
                              Just a little bit more sanding before I seal the decking.
                              OSE GIFTING ELF
                              HAPPY HOLIDAYS!!
                              • martno1fan
                                • Jan 2011
                                • 238
                                #60
                                Hi Jeff shes looking good m8,will you be adding any ridpads to the sponson bottoms?.
                                Mart
