A few other things I have completed:
Rudder is drilled and mounted along with the holes for the 4/40 pushrod.
To keep the water out of the boat I used a small piece of brass which I glued in place with some CA & epoxy then put a piece of water tubing over that which I will then zip-tie the pushrod seal to so everything is nice and clean on the transom.
I cut out an area in the rear stringer to mount the servo.
I made a mounting plate out of some 1/8" ply which drilled holes for some t nuts & then I epoxied that the opening I cut in the stringer.
Servo fits nice and snug and is right inline with the rudder.
I will take some photos of these and post them up soon as I can.
I plan to finalize the last few things over the next few days and test the boat ASAP!
