HJ's Mini Geico Cat,,,
  • HYDROJERRY
    • Jan 2010
    • 2503
    #106
    Hey guys i got some more work done on her,,,here's some pics!!! Stuffing tube in,,servo mount in,,,water outlet in,,all epoxyed with alittle peice of FG cloth over them!!!!
    • peells
      • 716
      #107
      Well it looks like you are getting close to taking her to the pond!! what are you using for a servo mount?
      Peter Eells; Fun, and Helping others To Have Fun!!!
      RC.Boats.by.Pete@gmail.com
      • HYDROJERRY
        • Jan 2010
        • 2503
        #108
        I went to lowes and got a stick of 1''x1/2'' angled aluminum and cut it out to fit a mini Hitec servo but before glueing it down i drilled some big holes in the floor section of it so the epoxy could squish threw it then cut a small peice of FG cloth to lay across it!!!
        I placed my esc in there where i want it but the motor wires are to short,,,the battery wires are ok so can i extend the motor wires to esc alittle or will it mess it up!!!!
        • HYDROJERRY
          • Jan 2010
          • 2503
          #109
          Wellppp almost done,,,now only need to make a hatch seal and get some of those hatch bolts to lock it down,,,then swishhhh in the water she goes but what sucks is it was like low 70's today and i didnt get her done but next weekend i hear its going to be in the 40's (DAM) i hate the cold!!!!
          • befu
            • Aug 2009
            • 980
            #110
            I do not care!!! this isn't about you!! If you wait until warm weather in the spring, I am going to have to take my wife and five kids on a vacation down there just to slap you!!! RUN IT!!!!!!!!
            OK, I feel better now I know what you mean. I was going to go out today and run as it looked like our last nice day of the year, but it ended up getting cloudy, cold mist and wind most of the day. ughh, I hate the cold also.
            This build is looking fantastic man, good job. i really hope it runs well after all this work you put into it. If not.... Here is to hoping
            Brian
            • peells
              • 716
              #111
              no you wont mess it up but I would consider moving the esc closer the motor, If it was me the servo appears to have long enough leads on it to support such a move and the esc doesn't weigh that much anyway that boat will have a rather strong pull to the right so use your turning very gentl until you get used to it!! you may need to turn left to keep it in control, How long is your mini?
              • befu
                • Aug 2009
                • 980
                #112
                It is 18.5" oal.
                • HYDROJERRY
                  • Jan 2010
                  • 2503
                  #113
                  Thats wright 18.5'' its a Befu special!!!! And trust me i cant wait to get it wet also going to order the hatch bolts today but ill be ready to just tape it up if needed when the weekend gets here!!!!!
                  • peells
                    • 716
                    #114
                    I gave up on hatch bolts because you really need to tape any way to keep the water out, I tried making a gutter all arount the hatch to channel water out to the back and everything the hatch being taped is the best. but dont pull the tape stright away from the hull pull it back along it's self as it reduces the surface tension of the tape and reduces the chances of pulling off paint (painter's trick when taping stripes) go out and have fun
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #115
                      Yeah i no but taping so far has started pulling the paint off my genesis hull and yep i pull it off like you described so now ill have to wax it up and hope that helps,,,but on the miniG i was hoping i could make a seal and save my paint,,,,maybe not..
                      • peells
                        • 716
                        #116
                        So Jerry What type of Paint are you using?
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          #117
                          I used Ace hardware brand Safty Yellow then i used many coats of Rust-o-leum Clear Laquer,,, i was useing auto motive clear coat threw a cheap spraygun but i have found the clear laquer works good or atleast on this paint job,,,and its from a spraycan,,,
                          • peells
                            • 716
                            #118
                            I use automotive paint that you have to mix and then clear coat over it with ppg shop grade clear which uses no reucer so it doesen't lift the other paint, you will need to be carefull with that one of your's but it looks sharp I cut my finger on the picture of it on my computer. LOL
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #119
                              Hahaha very funny man so whats up with your build i havent seen any new updates!!!
                              PS sharp as a razior////////...
                              • peells
                                • 716
                                #120
                                Sorry about you loyal followers of mine but duty called and I had to fix the Church's cordless microphone they dropped it and everyone yelled praise the Lord (They all thought it was the rapture), See these model building skills are great for other things as well (just keep it a secret or you will be kept away from your modeling) LOL
