HJ's Mini Geico Cat,,,
i dont think so, i thought i had it pritty straight but ill power it up tonight and check it,,do you think i need to wind it up or just give it alittle throttle like half way or something??
You may be getting driveline vibration. Does it vibrate bad if you give it a quick bench test?
Leave a comment:
I forgot this prob i have,, if i run it calmly its dry inside but if i run it WOT alot it gets water inside,, any ideas i put a peice of heatshrink on the stuffing shaft where it goes in the strut hopping this cures it..
Leave a comment:
Thanks Rum, the strut is even with the bottom edge of the ride pads,,as for detongueing the prop i dont no how and (I) wouldnt want to screwup the prop maybe i can send it to Iceman and get him to do it for me and S/B some of my other props at the same time.. Yeah i need to run it WOT to help keep it cool.
Leave a comment:
Looks fast Jerry! I'd bet that a lot of the heat buildup was because of the partial throttle running. How deep is the strut? You could detongue the x430 to free it up a bit also.
Leave a comment:
Hey peells,,, it was running loose and yes it has cooling. I ran it for a few laps not constant WOT,, if i put the 427 on the motor runs around 115, esc cool and bat cool... It has a velienon motor 3500kv 380 size i think and the turnigy marine 35 and 3s 1500mah lipo.. I took a vid and hope to get on here soon..
Leave a comment:
How long did you run it for? and do you have any cooling if not limit your runs to 3-5 min max, so how fast did it go? and was it digging into the water or running a little loose (nose up slightly)?
Leave a comment:
Well guys me and chud took both ower mini's out last weekend and i did like what was recomended and put on the 430 prop,,, the temps were supper high esc was hot motor was 145 and bat was hot not good any advise?????
Leave a comment:
well that will take a bit of time any way now be sure to put that see yourself shine on them
Leave a comment:
Well got my props but still need to SBP them but the weather for tomorrow was suppose to be in the low 50s and clear but now theyre saying mid 40s and overcast posible rain so i gess no boating tomorrow anyway!!!!
Leave a comment:
I just orderd a 430 and a 435 props,, ill try the 430 on my 3s and also try the 435 on my 2s and what happens,,,,
Leave a comment:
Im trying to get the BIG brother done first. I did get the rest of my parts in the mail today though to complete the Befu Special. Ive also got "that hull" Im working on.. Jerry knows what Im talking about. Too much stuff on the bench. I gotta get some of these off and cleared so I can focus on the little monster.
Leave a comment:
Thanks for following my build Mark...
Scott you better get crackin dude,, not like you to fall behind cuz then all you can see it my wake Bra!!!!!
Hey Befu ''thats right'' but i didnt say it,,maybe!!!!
Now i think everybody needs a special Befu Hull under there christmas tree this year...
Leave a comment:
Leave a comment:
