HJ's Mini Geico Cat,,,
  • befu
    • Aug 2009
    • 1064
    #136
    Prop up and try it again. I looked and peells runs a x430 on his 16" cat, so a step up might be in order. His KV is lower at 3200, but he is also runnign a 3s. OSE says his setup is good for 35mph.
    Again, your setup says 26mph on OSE calculator. Plus if you have a higher slip, that is going to make it worse.
    Yours: 27mm and 3s is about 35k rpm loaded and 39 mph indicated.
    Yours: 35mm and 2s is 34mph indicated.
    gives you some things to think about.
    Brian
    • peells
      • 739
      #137
      jerry Switch to a 3s lipo and change your prop to an x430 that is what I was using (am) then you will get some serious speed like my boat
      Peter Eells; Fun, and Helping others To Have Fun!!!
      http://rcboatsbypetere.blogspot.com/
      RC.Boats.by.Pete@gmail.com
      • peells
        • 739
        #138
        Thats funny BEFU was typing while I was watching your Vid and I must say I like what he said while I was reading and typing
        To Befu
        • 6S HYDRO
          • 1325
          #139
          also you know you have to give full power until on plane, i noticed you didnt hit full rpm till about 30 seconds. only reason it didnt plane
          • HYDROJERRY
            • Jan 2010
            • 2709
            #140
            It was strange, i gave full throttle and it took along time to get it up on plane!!! When i had my mini hydro running i ran it on 3s,,4600kv motor,,same esc and same prop,,,,the motor would get super hot but the esc wasnt,,,,so if i go 3s can i still use this esc???? ill order another prop but will be a week before i get it soooo do i need to order a prop and esc???
            Thank you for everyones help!!!!
            • CHUD
              • 554
              #141
              H/J
              LOOKS LIKE WHERE GOING BACK TO THE LAKE BRA
              • HYDROJERRY
                • Jan 2010
                • 2709
                #142
                thats wright!!!! I dont have a 430 prop so i found this plastic one and tryed to cut it down what do you guys think,,next to it is my 427 prop,,the blade on it maesures 10mm perblade and 7mm for the middle so i cut the plastic one 12.23mm so i think its close to the 430 size??? Its worth a try i gess!!!
                • peells
                  • 739
                  #143
                  Yeaa give it a try but dont be suprised if it breaks (plastic just isn't that tough) but give it a try and before you launch take pics of the set up up close so I can see how you got your prop angle (we) now go have fun
                  • wparsons
                    • 461
                    #144
                    Honestly, I think that plastic one is going to break first run.
                    I set up a mini rio with a 2040 3600kv inrunner on 2s and it's running a metal x432, coming in stone cold after every run. I don't see any reason why your bigger and torquier 28mm motor wouldn't spin a 32 or 35 mm prop easily on 2s, especially since there should be less drag with this cat than with a mono.
                    Light travels faster than sound, so people may appear to be bright until you hear them speak.
                    • Gerwin Brommer
                      • Dec 2008
                      • 928
                      #145
                      Can you show us a picture of the actual angle of the strut ?
                      And where is your C.O.G at , now ?
                      • HYDROJERRY
                        • Jan 2010
                        • 2709
                        #146
                        I will get the pics up soon but heres the new vids and yes the plastic prop made it half way around and didnt brake but bent the blades back!!! Enjoy The Fun... http://vimeo.com/17271196
                        • HYDROJERRY
                          • Jan 2010
                          • 2709
                          #147
                          And another!!! http://vimeo.com/17269127
                          • HYDROJERRY
                            • Jan 2010
                            • 2709
                            #148
                            Well im no pro on CG for sure but i think its about 6 1/2 or 7'' from the transum but i plan on cutting out some of the foam from under the nose and move the batt further forward,, and i got the strut as neutral as i could and as level with the bottom of the hull as i could... see pics
                            • peells
                              • 739
                              #149
                              where did yo get that prop holder? R2hobbies? BTW it looks like you had some fun!! much better trhan last run
                              • peells
                                • 739
                                #150
                                As far as I can see you must have made an adjustment at some point after the first run you made because on this last vid you went back to the original prop it looks as if you are real close to trimmed if not trimmed you did a good job on set up and it looks like you are going to have a lot of fun. Keep it up HydroJ.
