34" Scrath Built Cat
  • Norman2
    • Sep 2008
    • 354
    Hi, I used 3/32" on the bottom and 1/16" on the sides and top. Regards
    Norman
    34" Ekos Cat UL-1 Powered
    • Norman2
      • Sep 2008
      • 354
      Hi. Used 3/32" for bottom and 1/16" for top and sides all covered with silkspan and
      thinned out fiberglass resin. Regards
      Norman
      Sorry Double post
      • Norman2
        • Sep 2008
        • 354
        34" scratch built cat
        Hi, Finally was able to complete painting. Graphics will be ready Tuesday so once
        they are on I will clear coat and install Hardware and Electronics. Regards
        Norman
        • Alfa Spirit
          • 2183
          Very nice, may be Hydrolift replica?
          • Norman2
            • Sep 2008
            • 354
            #35
            Hi Alfa Spirit, It is going to have my own graphics similar to my 30" Shake N' Bake
            cat but in different colors. I agree it will look like the Hydrolift. Attached Photo of
            what I am trying to clone. Regards
            Norman
            • Alfa Spirit
              • 2183
              #36
              Nice too, ACME made chrome metal adhesive?
              Can you explain how did you made the rear pipes like Maritmo
              • Norman2
                • Sep 2008
                • 354
                #37
                34" scratch built Cat
                Hi guys, Got my graphics today and will clear coat in the next few days. Will then
                install the hardware, Motor, flex shaft and prop. All the electronics are in. Bad thing
                is I will have to wait for some warmer weather to try her out. Will post more photos
                when it is completed. Regards
                Norman
                PS. Exhaust were made from basswood and copper tubing from the local hobby shop.
                • rawsonreyes
                  • Aug 2007
                  • 102
                  #38
                  happy new year guys
                  hi norman guys this is the first for the year from me. great job norman can you give me some info on the minwax stuff i use west system epoxy but if i can get some thing cheaper it will be great.i am close to finishing my 31 shockerman cat got all twin drives just needing two esc' looking at 9xl best recomendation.also need some balsa shop info the shop here in trinidad wi does not have the 1/32,1/16 skins any help will do.thanking you guys rawson reyes.
                  • Norman2
                    • Sep 2008
                    • 354
                    #39
                    Hi Rawson, Welcome back to the forum. The Minwax product I used on the new cat
                    is Fast Drying Clear Satin Polyurethane. It is easier to use than fiberglass resin
                    to seal the frame and hull. Only drawback is it needs about three coats to do the
                    job. Our local hobby shop carries all sizes of balsa, plywood, and basswood. I would
                    suggest you go to the Tower Hobbies site and they carry all sizes and types. Hope
                    this helps. Post some photos of your build. Regards
                    Norman
                    • Jesse J
                      scale FE enthusiast
                      • 7818
                      #40
                      Well Norman, you have out done yourself! Amazing work and quite speedy as well.
                      Cheers, Jesse
                      "Look good doin' it"
                      See the fleet
                      • Norman2
                        • Sep 2008
                        • 354
                        #41
                        Hi Jesse, Thanks. I had to build a bigger one than my
                        30" incher in order to get more space for the electronics.
                        My fingers are too big. I just hope it runs as good as the
                        other one which is now a static model. What are you building or planning. Regards
                        Norman
                        • Norman2
                          • Sep 2008
                          • 354
                          #42
                          34" Srctch Built Cat
                          Hi, Finally finished my 34" cat. Now to wait for spring until the lakes are no longer
                          frozen up here in Western North Carolina. First I am going to power it with and
                          extra Ammo 36-50-2300 which I have lying around but finally I ordered an Ammo
                          36-56-1800 which will be the final set-up. Have not decided on ESC but will probably
                          be an Etti. Octura X640 Prop and 4S Lipos. Hope you like it. Regards
                          Norman
