34" Scrath Built Cat
  • Norman2
    • Sep 2008
    • 354
    Hi, Just received my laser cut parts from Alex Guzman and will start sometime
    next week. It will be a 34" OAL cat from Shockerman's plans. I will be making some
    slight changes and will post photos from stages of the build. I am inclined to
    power it with a 580L but will wait for later to decide. Regards
    Norman2
    PS. Will be just for sport with different paint scheme. Thanks to Alex for a super job.
    34" Ekos Cat UL-1 Powered
  • bustitup
    • 3072
    Originally posted by Norman2 View Post
    Hi, Just received my laser cut parts from Alex Guzman and will start soemetime
    Norman2
    lot of work ahead of you...nice
    curious as to what the lazer cutting bill came to...he cut your wood or his?
    • Norman2
      • Sep 2008
      • 354
      Hi Bustitup, Cutting was $50.00 plus $20.00 shipping. He does excellent work. This
      will keep me busy Winter and part of Spring for the painting. Regards
      Norman
      PS He provided the 1/8" plywood
      • bustitup
        • 3072
        Norman
        so basicly he supplies the "hull kit" for $70 shipped? and you just give him the cut sheets?
        sweet deal
        gl with that fun build
        • Norman2
          • Sep 2008
          • 354
          Hi Bustitup, I provided him with a PDF File but he already had one and just scaled it to 34"
          Regards, Norman
          • Norman2
            • Sep 2008
            • 354
            34" Scrath built Cat
            Jim, Attached photos of the steps on my 30" cat. I will be doing them the same
            on the 34" cat I am now building. Will have more photos this afternoon. Regards
            Norman
            • Norman2
              • Sep 2008
              • 354
              34" scratch built Cat
              Hi, Started the 34" cat and will document the build. First stage completed with
              the frame. As you can see I always indent part of the transom as I need the
              space for my hardware to get the prop/rudder where I want it. Next flotation and
              pre-fitting the hatch and Canopy. Then prepare bracing for sheeting. Regards
              Norman
              • CornelP
                • 793
                Looks lovely in that size... I started another 30" but widened it a bit (by about 2cm), will start a thread when I get a bit further... just to make sure it turns out the way I want...
                I changed the angles of the steps to perpendicular and will probably add a ridepad later on.
                Any plans on hardware?
                • Norman2
                  • Sep 2008
                  • 354
                  34" scratch built cat
                  Hi CornelP. Attached photo of hardware to be used. I built a 30" cat but wanted a
                  slightly larger one to make some changes which I did not do on my original one.
                  I did not change any angles as my 30" handles excellent both in straights as well
                  as in turns so hopefully it will work the same in 34". Regards
                  Norman
                  • Alfa Spirit
                    • 2183
                    What is this ??
                    • Norman2
                      • Sep 2008
                      • 354
                      Hi Alfa Spirit. It is a thin piece of Carbon Fiber to cover an accident with a screwdriver when
                      I poked a large hole through the bottom. Only on my 30" cat. Regards
                      Norman
                      • j.m.
                        • 847
                        I would think that running the strakes all the way to the cut on the steps would be preferable, they look like they would be scrubbing a lot of speed with the blunt nose.
                        • Norman2
                          • Sep 2008
                          • 354
                          J.M. You are totally correct. I have been told before and will be placing the strakes
                          how you advised on my new build (34" version). Thanks for the advice. Regards
                          Norman
                          • Norman2
                            • Sep 2008
                            • 354
                            Hi, Some photos of progress today. Installed floor (inner and exterior) also
                            installed place for batteries etc. in the sponsoons. Prepared canopy and hatch
                            and pre-fitted. Next fiberglassing interior, flotation and finally sheeting. Regards
                            Norman
                            • Norman2
                              • Sep 2008
                              • 354
                              Hi, Due to all the snow was able to complete the sheeting. Now it will be a lot of
                              sanding, putty, primer and get ready for final painting in spring. In the meantime
                              will get hardware sorted out. Regards
                              Norman
