Hi, Church is canceled due to the 8+ inches of snow in Western North Carolina so I will get to
do some work on the 34" cat. Have the strakes on so next step will be the finishing. I am going to
enumerate the steps I use to do the finishing,
1. Be patient, do not try to hurry finishing prep or final painting.
2. Sand hull and hatch with 200 grit sandpaper. Correct any imperfections like pin holes,
joints, etc. with wood putty and re-sand.
3. Wipe hull with a damp cloth to open the grain on the balsa. Once dry give one coat of
fiberglass resin diluted with Acetone so the balsa will be impregnated with the fiberglass.
Let dry completely.
4. Sand with 300 grit sandpaper until you feel it is smooth. Another coat of Fiberglass Resin with silkspan
on the bottom and sides. Sand until smooth.
5. Time for Automotive heavy primer. I only use Duplicolor Truck and SUV Primer, Color, and
Clear Coat. This is because they are all lacquer and will not wrinkle. I usually use three
or 4 coats of primer and sand between coats with 1000 grit sandpaper. Once I am sure
everything has no flaws I will use three coats of paint (Color of choice) sanding the first
two coats. Then Final coat of color Paint.
6. Place graphics of choice then two coats of Clear Coat. Let dry completely between coats.
7. Install electronics hardware and go to the lake and have fun.
I am sure there are other methods so I am just listing these as the ones that have worked
for me. This is not the only way, only the way I do it. Hope this can help all scratch builders.
Merry Christmas and a Happy New Year.
Norman
PS. Worst thing you can do is mix Lacquer with Enamel. Creates one hell of a mess.
Reason: forgot some stuff
Instead of thinning the epoxy with acetone (which kills the chemical reaction) just warm the epoxy when it's in the mixing cup. If you have a good slow laminating epoxy (40-60 minute pot life) then it will kick off in a reasonable time when heated.
Coating with minwax polyurethane is also a great option if you do not want to use resin. Water clean up as well. It soaks in very nicely. After that then use a high build sealer/primer.
Block sand to keep it straight....really want it the ultimate then lightly fog the final prep with a color coat then lightly block sand to find any dips or high spots.
Thanks guys. I think I will stop the Fiberglass Resin and Use Jeff's method of using Minwax
Polyurethane. Thank god for this tip. No more messes. regards
Norman
Hi, Attached photos of the Cat almost ready for paint. Still a few more primer coats
and final sanding, and if weather permits will start painting. Regards
Norman
Hi Alfa Spirit, I wish I had the ability to do that kind of beautiful paint job. Mine will
be all Ferrari Red with the Shake N' Bake and Proton Graphics in Red and Yellow.
Will Post pictures soon. Regards
Norman
