TFL Carretero
  • T.S.Davis
    • 6228
    Did finally get this baby wet. Runs really smooth. Might need more fin on the right side. Haven't quite figured out the prop situation yet either. Needs big 2 blade that I just don't have. Like maybe 462 sized. I can't even warm the batteries up with the props I own.
    Sure looks sweet in the water though.
    Noisy person
    • Darin Jordan
      • 8332
      Terry,
      What SHAPE are the current turn-fins. If they are tear-drop shaped (seems to be the rage these days), try something more like this:
      ProBoat Impulse 31 V1 & V2 Turn Fins by OSE
      http://www.offshoreelectrics.com/pro...?prod=ose-1400
      I assure you, it WILL be better, especially in real race water...
      Darin E. Jordan - Renton, WA
      • T.S.Davis
        • 6228
        Maybe. I suspect it's a size thing though. I try to use the smallest fins I can get away with but this things weights a bunch with 8s12000mah.
        Noisy person
        • Darin Jordan
          • 8332
          Size matters, but surface area counts as size... :) The difference between finishing a P-Ltd Mono or Offshore race with an IM31 is these fins over the stock teardrops, and these aren't as deep... The boat is a full-throttle pin it in the corner boat with these. It's rolled over upside down with the stock ones...
          Hey, I'm just here to help!
          • T.S.Davis
            • 6228
            #35
            I have a number of fins I need to invent. My Q sport absolutely can not hold a turn. I do have a plan for that at least.
            I nice sheet of fin on this would be easy enough to do.
            Noisy person
              • 9438
              #36
              • T.S.Davis
                • 6228
                #37
                oh.....Square straight fin with a whole and an edge on it. Super easy to do its all I meant.
                Noisy person
                  • 9438
                  #38
                  I tried a set of small Speedmaster's cut down for my P-mono and it turned like crap... not the fins problem just the rest of my setup didn't like them... Pond time... there is never enough.
