TFL Carretero
  • Jeff
    • 233
    Darin, you shouldn't have to use a calander to time a heat in any class.
    I try and avoid paste eaters.
    • T.S.Davis
      • 6266
      Jeff, I've not heard a single person confused about lengths.
      Darin, you're running mid 40's in N1? Nice. I should run out and buy one.
      Noisy person
      • Jeff
        • 233
        terry terry terry.Are you the guy being interviewed on wayne's world?
        • Wetter
          • Aug 2013
          • 241
          Why is there no RC TV reality show, especially with all the knowledge and great people here and other sites someone has to know somebody in TV.?
          serious i have been thinkn' @ this for some time, boost sales, interest, and just plain fun.
            Why??? Look at how some of the threads go down south, no major network Could Afford That Kind of production glitches!!!
            • Darin Jordan
              • 9446
              Terry, would you leave the kid's toy's alone??
              I suggest you run out and buy your son or daughter a T-Mono instead...
              Darin E. Jordan - Renton, WA
              • T.S.Davis
                • 6266
                Darin, he already asked me if he could run it. Wants to run the 1/8 scale too. He tried to get Pete to let him run his Q sport a number of times.
                Ray, that's the old style Castle 240HV. They were giving them away about a month ago so I grabbed a couple of them.
                Wetter, some of us are a'holes but we are an entertaining lot aint we? We're just as stupid in person. It's what makes these races so fun I think.
                Noisy person
                • T.S.Davis
                  • 6266
                  Speaking of gigondous' motors. Look how much beef this one will be carrying.
                  Noisy person
                  • rickwess
                    • Apr 2013
                    • 777
                    Terry. Where did you get that motor mount?
                    • T.S.Davis
                      • 6266
                      That's an old Fightercat mount for a 2230. It was way too long for a 2215 so I made new mount rails for it from scratch. Did all the drilling and tapping accordingly. Major league pain the behind.
                      It's just laying in those slots right now until I get the stuffing tube lined up.
                      I think I'll make some supports to tie those rails to the gunwale. Sort of a ladder effect. Then maybe some two part foam. This will have gobs of power. It may tear the rails loose from the hull if I don't add some structure.
                      Noisy person
                      • rickwess
                        • Apr 2013
                        • 777
                        Thanks.
                        Makes sense about the extra support, especially given the rails end right at the back of the mount.
                        • T.S.Davis
                          • 6266
                          CARRETERO 3.jpgCARRETERO 4.jpgIt's about done. Needs fins. Still have to put some latched on the lid. Still debating how to do that.
                          Noisy person
                          • axel
                            • May 2007
                            • 136
                            Well Terry adding structure is a good idea,if its from the same place as mine was.
                            She is good for running far over 60.
                            • T.S.Davis
                              • 6266
                              That's encouraging. I was concerned with lower strakes coming so close to the trans that it would ride too high in the water.
                              I've got rails, the tray, and the motor mount tied together and that ladder is tied to the transome so hopefully there is enough structure.
                              Noisy person
                              • axel
                                • May 2007
                                • 136
                                Terry she runs marveless , it was one of the best handling Monos in that size i had,in chop and glass water. COG is between 27-29% depends on the water.
                                My setup was T600/1400 with 6S2P5800mah no Trimm and Turnfin Stinger parallel to waterline as long you don´t want to run Oval you don´t need them.
                                Top of the line was a Prather 245 but then the Motor got quite hot , the Hull ran stable evan by choppy water.
                                A friend of mine had some hard impcts by blowoffs and the hull didn´t like that.So if you want long time fun stay at about 55 and avoid rhe blowoffs.
                                All only if it comes from the same place mine came from.
