    • 7277
    #241
    I'm running my strut all the way up. Depends on props, and CG.
      • 5660
      #242
      Thanks guys! Appreciate your help!
      • flraptor07
        • Aug 2013
        • 2451
        #243
        [QUOTE=tlandauer;537854]Tell me about it, just found out the TFL 3/16 shaft ( threaded part ) is too big, none of my Octura props would go over! Grim Racer props on the other hand have no problem. Good thing I have a Kintec 3/16 Flex/shaft.
        I had the same problem with the threaded part of my flex shaft too, The problem is that the threads are too tall. I carefully filed the tops of the threads off them ran a die back over it just in case any threads got too flat. now all my props work fine.
          • 5660
          #244
          [QUOTE=flraptor07;538129]
          That is a very good approach! I just did the elementary school thing : shortened a new Kintec .187" Flex /cable. But I found out this--- just turning the stub shaft ( with the whole cable all the way inserted into the collet w/o tightening the collet so it free spins) with my fingers , the Kintec cable/shaft has barely detectable friction where as the stock TFL one piece welded shaft was much harder to turn. The stub shaft is shorter on the Kintec and I also wonder if the cable is ever so slightly thinner in its diameter. Although my caliper tells me that they are the same.
          I will have to remember your trick, but have to get a die first. Always new this and that.
            • 5660
            #245
            Guys, check you hatches, I cracked mine in the front with very little pressure. I looked closely afterwards and realized it is so thin, almost only the gelcoat... maybe just mine. I laid two lateral heavy FG tape both front and back and two more strips( light weight FG tape) longitudinally along the outer portion of the hatch. It feels much sturdier yet still with enough flex so one can squeeze the hatch in order to mount flush---if yours is like mine.
            Black permanent markers have a bad habit of oozing out when mixed with Epoxy.
            • flraptor07
              • Aug 2013
              • 2451
              #246
              Popeye progress so far..
              Here's the progress on my Popeye so far, I wasn't real happy with the thickness of the AQ turn fin so I made one from .062 aluminum instead of the .045 it was I also changed the shape, size, and radius a little. Put a dual cooling rudder on it and re epoxied the stuff tube with JB. Here's some pics... DSC02284.jpgDSC02285.jpgDSC02286.jpgDSC02291.jpgDSC02297.jpg
              • flraptor07
                • Aug 2013
                • 2451
                #247
                More pics....
                  • 5660
                  #248
                  Looks real great!
                  I love everything you have done, especially the servo mount. I had a turn fin made similar to yours but straight w/o the curve just incase.
                  The green lines over the wires are fab. What motor is on?
                  You matched the paint on the vertical fins well, that is cool.
                  What else have I forgotten?
                  You plan to use another thru the hull fitting for the second water line? Check the factory one, mine just fell out, lol...
                  What is the reason for the unsharpened bottom portion of the turn fin? Must be a reason...
                  • JimClark
                    • 5902
                    #249
                    Whats up with that rudder never seen one that wide seems like that would be a problem
                    Billy Graham
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #250
                      Looks real great!
                      Thank You! The motor is a Neu 1515 1Y 2200kv, I did add another thru hull fitting for water pickup and replaced the original one so both are now screw in fittings with nipples on both sides. I didn't think it was nessessary to sharpen the bottom of the turn fin because it's not on the leading edge. This way it's more like a airfoil, I can always sharpen it later if needed
                      The rudder is the dual pickup replacement and yes it's pretty wide. I checked and depending on prop size there may be clearance issues but I can always adjust the end point on the steering to cure that.
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #251
                        Doby or whoever has exp. with Popeye, what's a good starting point on props? Neu 1515 1Y 2200kv on 4s, I have a X447 that actually measures 46mm. I was thinking about starting there.
                        • RandyatBBY
                          • 3915
                          #252
                          I know I read it some hare what size is it?
                          Randy
                          BBY Racing
                            • 7277
                            #253
                            32" Randy.
                            I run a 447 3 blade with my 2200Kv Leopard. It will take a more aggressive prop next season as the motor and controller were always barely warm.
                            • ron1950
                              • 3024
                              #254
                              doby what is a more aggressive prop? I ran a m545 and a nue 1515 2200 and like yours barely warm...whats next?
                                • 7277
                                #255
                                Any idea of the speeds you were getting?
