  • Darin Jordan
    • 9446
    #181
    ya thanks darin...seems the biggest problem I have right now is cg back of sponson about 2 inches ...hopefully that's not going to be bad as I cant seem to get the gc farther forward
    That's the typical problem with a Pickle-Fork design... On most of those I've had, weight had to be added to the sponson tips. On the Stealth 30, we poured epoxy mixed with lead shot.
    Darin E. Jordan - Renton, WA
    • ron1950
      • 3082
      #182
      hope it doesent come to that epoxy lead shot stuff but I may think about it
      • sampit
        • Jul 2009
        • 466
        #183
        We are building a scratch build Popeye for that reason, the factory COG is probably OK if your your running a small 3660 motor and small 4s packs, but start adding bigger motors and bigger packs, it need to way further forward this one is being set up for 6s Dinogy 5100 and a TP 4082 1450kv
        couldn't set the cog running the 6s pack lengthways.
        its set at one and half inches from the heel, ( thanks Paul)
        just need to epoxy the carbon inlay in, order some hardware, to do a final check.
        In the mean time, we would like to blue print the sponsons, or maybe add some ride pads, as the sponsons are a little bit out and rocky,
        Any one help with blueprinting or adding ride pads? Sure it would make a big difference, but not sure what's the best way to deal with it.
        FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
        Popeye Hydro T600 1400kv 6s1p
        • Wetter
          • Aug 2013
          • 241
          #184
          i love spinach, i want Popeye But ML 36" is more up my alley.
          but ATR is somethn' i can follow, just wish i did not have to order across sea.
          • ron1950
            • 3082
            #185
            btw found out last night why it chine walked and blew over for no apparent reason....the AQ turn fin brace has a wide hole in the bottom bolt hole for adjustment.... it was slipping badly super hard to get to the nuts that hold that brace inside the boat....so the slightest right rudder pulled the turn fin out almost a quarter inch but ill get it fixed and try again see what it will do
            • Heaving Earth
              • 1929
              #186
              When I have slippage between two parts as described, I take some 80 grit paper and rough the two surfaces that contact each other. Do that and it won't slip anymore
              Sent from my iPhone using Tapatalk - now Free
              • Jeff
                • 233
                #187
                Ron, would you be able to scuff up a piece of 1/4 inch aluninium flat stock and epoxy it in there? You could then drill and tap some screws from the outside.
                I try and avoid paste eaters.
                  Or a center punch on one of the inside surfaces will do too.
                  • ron1950
                    • 3082
                    #189
                    I may try again to get it tight and may put another nut and bolt in the open slot...it wont be that big a prob;lem
                    • Heaving Earth
                      • 1929
                      #190
                      Yes but will that not cause issues if you want to make a slight adjustment? I'm trying to visualize what you mean.
                      Pardon my ignorance here
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #191
                        Depressed
                        I'm so depressed, I just tracked my Popeye and it said "Failed Delivery" Returned to Sender. Not sure what happened but I'm sure it's gonna be a couple more weeks before I get it now
                          • 7512
                          #192
                          That sucks....maybe you don't live where you think you do
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #193
                            I thought I lived where I thought I did, but maybe I don't
                            • ron1950
                              • 3082
                              #194
                              call your post office tomorrow and ask what the heck!
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #195
                                Oh Trust me, that's the first thing I'm doing in the morning!
