    • 7512
    #151
    its only 32" long.
    As for the other measurements for the two organizations...some are straightforward...others are difficult to comprehend...again, someone who actually knows how to interpret them, tell me and I'll measure...not going to waste time otherwise.
      • 7512
      #152
      Originally posted by Jeff View Post
      It apears to measure over 35 inches long. So it would be a Q boat, not a P or P-limited.
      I wouldn't have started two "P" threads is the length was over 34"
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 1058
        #153
        Doby,
        Take a picture of the bottom, open it in Microsoft paint and draw lines to show the various measurements. We'll help you figure it out.
          • 7512
          #154
          The boat actually doesn't look too bad from an appearance standpoint. Can you post some pics of the bottom?
          Also, some dimensions I'd be interested in seeing:
          1) Tunnel width 173mm
          2) Pickle-Fork Depth (tips of sponsons to leading edge of center section)
          3) Transom width at it's narrowest point 185mm
          4) Tunnel Depth at rear-most of ride-pad 25mm
          5) Distance from aft of ride pad to the transom 445 mm
          6) AoA
          7) Dihedral angle
          8) Tunnel break location
          Added some dimensions above
            • 7512
            #155
            Originally posted by LuckyDuc View Post
            Doby,
            Nope...somebody show me a diagram of how to measure the rest....I'm interested in others interpretations of the rules...should be interesting to see how many are different....so far no-one has answered my initial request.
            • ron1950
              • 3082
              #156
              the 895mm lenth is wrong...its 822mm or 32. something inches
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 1058
                #157
                OK?
                I can't interpret what I can't see or measure.
                A picture would help in guiding you for measuring
                  • 7512
                  #158
                  Sean...read the NAMBA rule book for P-Sport...draw me a pic
                    • 7512
                    #159
                    Hull length =32 inches
                    • Jeff
                      • 233
                      #160
                      Did you use the namba guidelines for measuring a boat to come up with that?
                      Since the rule book scares you.
                      4. Hull Measurement Guidelines
                      a) When a hull minimum or maximum length measurement is specified for any
                      class, that hull will be measured by placing two vertical straight edges at the
                      furthest points fore and aft of the bow and transom of the hull. The distance
                      between those two vertical straight edges will be measured. Hardware will
                      not be included in the measurement.
                      b) The hull will be placed between those two vertical edges and situated in the
                      same horizontal position in which the hull would ride on the water. Any
                      flanges, “shoebox” overhangs or other parts of the hull that are part of the
                      original manufacturing process will be included in the measurement.
                      I try and avoid paste eaters.
                        • 7512
                        #161
                        P max is 34"...this boat is 32" should..not be to hard to understand for you.....under 34=P...over 34=Q
                        Read the NAMBA rule book......its some of the other things in the Electric P-Sport section that are "confusing"...not scary...Although it is close to Halloween.
                        • ron1950
                          • 3082
                          #162
                          jeff give it a rest the 895mm is wrong its only 32 in or 822mm...
                            • 7512
                            #163
                            Section #20 of the NAMBA rule book, para 12 actually has a diagram...so that helps.....
                            So...
                            #10 says: no boat shall have an afterplane greater than 60% of the total hull length..
                            overall length is 812mm
                            60% would be 487.2mm
                            actual measurement is 455mm...which is less that 60%
                            My interpretation would be that it meets this requirement.
                              • 7512
                              #164
                              Now lets go to section C, para 2 of the FE Sport Hydroplane rules:
                              Riding surfaces must be in the front 50% of the total hull length.
                              50% of that would be 406mm
                              actual measurement is 455mm from the transom.....which is more than 50%
                                • 7512
                                #165
                                Now lets go back to the diagram in section #20....
                                On pickle fork hulls the open area should not exceed 25% of the total hull length....A+B in the diagram.
                                25% of that would be 203mm
                                actual measurement is 170mm.....which is less that 25%
