  • Jlov
    • Nov 2013
    • 825
    #481
    Yes Doby saw that tip about scuffing up hull and tube from you earlier in the thread. I found this in an older thread on here. Seems like a easy enough process to follow.
    Stuffing Tube installation:
    To "determine the angle" of the stuffing tube slot, I mount the motor, then put a 3-4" rod or piece of flex shaft in the collet. The hull end of the shaft will point to the right spot to drill the first hole. From the bottom of the hull pencil in two horizontal lines on each side of the hole, aft (towards the transom) from the hole the same diameter as the stuffing tube. Then use a rat-tail file about the size of the hole (or file of your choice) to make to make a 3/4"-1" long slot towards the stern. File the forward end of the slot just enough to match the angle of the motor shaft. To smoothe out the horizontal sides of the slot, use a flat bastard file. EZ to file off too much, so go slowly.
    To align the stuffing tube with the prop strut/motor shaft, mount the strut, adjust it so the bottom of the strut is even with the bottom of the hull & horizontal (Placing the hull on a table or other flat board makes strut shaft alignment EZ). Then firmly tighten all strut screws in perparation for mounting the stuffing tube. Installing & aligning the stuffing tube take trial & error & time.
    1. insert the stuffing tube from the hull bottom to 1/2" from the collet, then into the strut.
    2. The tube should be level horizontaly with the strut. If not, remove, and in VERY small steps, adjust the bend of the stuffing tube slightly, reinstall & check alignment.
    Repeat step 2. as necessary until it's properly aligned.
    Once the stuffing tube is aligned, seal the edges of the slot, inside & bottom, of the hull with a good epoxy to keep it from rotating under torque.
    • Jlov
      • Nov 2013
      • 825
      #482
      My hull came today... Now just waiting on all the hardware
      Thx again to Tom Castellani at Ampeaterracing.com for braving a blizzard to ship same day and get it to me in Florida in just three days from date I paid! The hulls are only $140 shipped from them
        • 5660
        #483
        Looks good!
        Let the fun begin!
        • flraptor07
          • Aug 2013
          • 2451
          #484
          Get Busy!!! You can trim about half of the lip out of the opening in the hull and make more room to work in there. Plus it makes it easier putting your batteries in and out.
            • 5660
            #485
            Chris, got a Neu 1515 but it is too short for the rear ring?? How did you do it?
            Thanks
              • 5660
              #486
              The motor that arrived yesterday has screws outside on the can to hold the end plate, I see your picture the ring is on the very rear, guess Neu changed their style?
              • flraptor07
                • Aug 2013
                • 2451
                #487
                Thanks
                It's not really too short, what I did was take my dremel with a metal bit and make notches in the ring for the screw heads. Then it will go on right at the end of the motor.
                  • 5660
                  #488
                  Got it! Thanks!!
                    • 7277
                    #489
                    Going to make sure I have lots of gas in the tank for P-Sport.
                    I have an 8000mah 30C Zippy that now fits in quite nicely.
                    In either configuration, the CG is between inch and 3/4 to 2 and 1/4" and can be varied a bit if required.
                      • 9438
                      #490
                      from China or USA warehouse? I like the 8000 zippies.
                        • 5660
                        #491
                        I did it, it was a pain tho, lol... But I always wanted a Neu 1515 in my Popeye!
                          • 7277
                          #492
                          It came from Daniel.....he loaned it to me last winter to see if it would fit in some boats.!!!!!
                          I did see it in their US warehouse and they do ship LiPos to Canada from there.
                            • 9438
                            #493
                            Cool, thanks.
                            Tland, try a 1521 1.5D and that candle will light right up... Sorry, Popeye..
                              • 5660
                              #494
                              Speaking of motors, ( excuse me for leaving the topic), why nobody uses the 1518 series?
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #495
                                Cool, thanks.
                                I've got a 1521 1.5D I could try I bet it would really fly with that
