  • Jlov
    • Nov 2013
    • 825
    #466
    Yes (2) 2s in series to make 4s right?
    • flraptor07
      • Aug 2013
      • 2451
      #467
      Originally posted by jlov View Post
      yes (2) 2s in series to make 4s right?
      correct!
      • Jlov
        • Nov 2013
        • 825
        #468
        Hull will be here Friday and all the hardware from OSE and Kintec should be here by Tuesday... Hate the waiting though
        • Jlov
          • Nov 2013
          • 825
          #469
          If anyone is looking for a Popeye I saw this on rcuniverse.com He's even willing to trade!
          http://www.rcuniverse.com/market/item.cfm?itemId=962383
            • 9481
            #470
            LOL
            they guy took a picture of his computer!
            • sampit
              • Jul 2009
              • 466
              #471
              Any one built their Popeye to run on a 6s setup,or am I the only one? wondering how a a Y547 would run on 6s with the TP 4050 1450KV the calcs looking like it should be around 60mph, if it stay on the water long enought.
              FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
              Popeye Hydro T600 1400kv 6s1p
              • flraptor07
                • Aug 2013
                • 2451
                #472
                Most everybody is building this to run P classes and P is a 4s max so that's why you don't see many on 6s. I've been just a little above 60 on my 4s setup but not consistantly. That was with the hull mod and I'm still tuning.
                • Jlov
                  • Nov 2013
                  • 825
                  #473
                  Hey Chris where did you get the green braided tubing cover? Thx Jeff
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #474
                    Right here, This guy has all different sizes and you'll need some green heat shrink tube too.http://www.ebay.com/itm/1-4-10FT-BRA...94dfd3&vxp=mtr
                    • Jlov
                      • Nov 2013
                      • 825
                      #475
                      Cool thx,,,,found this place and they were right here in Fl so ordered some from them. Was only .40 cents a foot too. Jeff
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #476
                        http://www.cableorganizer.com/braide...colored-pet%2F
                        Good deal man, I saved that one myself!
                        • Jlov
                          • Nov 2013
                          • 825
                          #477
                          Hull will be here tommo. Is there a thread anywhere on here about installing stuffing tube? Its only part that's got me worried! All other boats Ive had came with tube installed. Tim gave me these pics to help with location of tube which will really help but a little unsure how to start and then drill stuffing tube hole. Thx Jeff
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #478
                            A little advise, since you're mounting everything from scratch, mount the motor about 1 1/2" futher forward than in that pic. We've been having trouble getting the CG far enough forward that should help a bunch! Then mount your batteries crossways in front of the motor.
                            • Jlov
                              • Nov 2013
                              • 825
                              #479
                              Ok will do....no advice on stuffing tube? What size drill bit and do I start the drill hole from inside tub or on outside bottom of hull? Heres the stuffing tube I bought from Kintec:
                              Brass Tube Replacement stuffing tube with liner. 300mm long (12"). $6.00
                                • 7512
                                #480
                                [ATTACH=CONFIG]111297[/ATTACH][ATTACH=CONFIG]111298[/ATTACH]
                                JB Weld is the adhesive of choice for most people.
                                Be sure to scuff up the outside of the tube and the hull where the JB weld will be applied. I use an 80 grit sandpaper for that.
                                Before drilling, measure 20 times to be sure.
                                Mount the strut to the transom so it can help support the stuffing tube while the JB weld is drying.
                                Pick a drill bit that's close to the size of the tube, but keep in mind you will be drilling on and angle, not at 90 degrees to the hull.
