Drive shaft and Prop shaft are 3/16. The prop is 37.5mm. The decals look authentic. Pics coming as soon as I have it set up.
New HK Mono
OPP Racing "Other Peoples Parts!"
Island Boys Fast Electrics
I gotta jump in here, because I'm not sure how a 4 pole motor would feel any different. I own several 4 pole motors that feel different when you turn them. Some feel tight and some spin freely. Can you explain what you mean ray?Originally posted by ray schrauwen View PostSo does the motor have that tight cogging feel of a 4-pole or does it feel more like a 2-pole?
Ray, it has the feel of a 4 pole. though you can spin the motor shaft with your fingers, its NOT as "tight" as the Aquacraft stock SV27 motors. hope that helps, will post more pics shortly.OPP Racing "Other Peoples Parts!"
If you turn a 4 pole motor by the shaft, well at least most of them.. you an identify the number of steps it has. Some are tighter than others but, most all except the Silver EDF hobby king 1900kv and 1600kv have steps you can feel much more so than a 2 pole Feigao, Feisuda, etc. Lehners have no cogging whatsoever, at least the ones I have don't. Two pole motor usually feel like the magnet will only fall into 2 positions from my experience.
Originally posted by Heaving Earth View PostI gotta jump in here, because I'm not sure how a 4 pole motor would feel any different. I own several 4 pole motors that feel different when you turn them. Some feel tight and some spin freely. Can you explain what you mean ray?
Ray ive noticed that TFL Hobby have changed the motors their fitting in to their boats, not the same boat i know but i have a recent Genesis cat that has the black motor fitted thats a 3674 2075kv. This motor is deff differnt to the more usual 2 pole motors they were fitting to their boats, as you describle the 2 pole motors only cogged twice per revolution & weak at that. The newer motor i have cogs around the same as a Leopard 4 poler & cogs 12 times per 360degree turn.
That's cool and that's what I suspected. It would be nice if they sold the motor separate as a repair item or something? The 36x60 one that is.
DSCF0458.jpgDSCF0460.jpgDSCF0461.jpgRay these are pics from inside the 3674 motor to give an idea of the diff from the old 2 pole motors.
