56-102 Monster coming down the pipeline
This topic is closed.
  • Punisher 67
    Ignore list member #67
    • 1616
    #196
    Keith I haven't a whole lot of experience with the 2280's but I did have one in a 35 mono on 8 cells and it was a rank setup infact the hull was completely destroyed in a crash , It was a 2280/7 and for me the number 7 for Lerner's is a lucky number . Seems for my apps that config works the best . My main experience is with the 45 - 60 inch boats . the 3080/7 and Neu 2230 /1Y are almost carbon copies of each other with size and weight with the lehner weighing about 5% more . ,My two Snipers running the same cells , same prop , everything else runs about 5% faster with the 3080 and eats about 10% more for amps and time as apposed to the 2230. So the closest eaquivs between Neu;s and Lehners are the 2230/1Y Neu's and the 3080/7 's both with virtually the same KV'S and power output - the 3080 in this app has the upper hand in my experience
    The Hor SS5694 competing in this arena is beyond a laughable joke ( twissted )
    Never owning a Neu 2230 or a Lehner 3080 and then running them side by side how con you possibily make any comparison with some magic motor....Hor 5694
      • 7512
      #197
      Originally posted by Punisher 67 View Post
      Twissted being a Lehner owner of 3 X 3080'S and 3 X 2280's I am going to clue you in a bit here - as always you always get what you pay for and the Lehners are no exception . There is no motor out there that is built like the Lehner line they have a very unique rotor design and are just packed full of wire making them easily one of the most efficient designs out there . Neu 's are also well designed but as of late I see some quality control issues hopefully that will be nipped in the butt . But needless to say a very large and extremely powerful line of motors .
      So the big question why was the speed so close - Maybe cause the KV was also close between the two design's and with the same cell count the speed would have been close also . Now lets start adding power well past the manufactures rated limit similar on both motors and see if the high precision Chinese motor can handle the heat - I 'll bet you it grenades well before the Lehner even see's any stress . I noticed on your pictures of the 5850 that it was Herve from the uniques section logo next to the motors so can you explain why you are using someone else's product to make your point . I do not know you and I do not want to insult you either but you certainly have made a few ignorant assumptions .
      i cannot put this any nicer but there is no F**KING way a Hor SSS5294 will push 12KV on a continual output and anyone thinking it will is an absolute retard . There is just not enough motor or mass to support those kind of numbers unless it is just for a few seconds on a saws run . I have seen the inside of a 11KV Lehner 3080 and also the pinner interior of a 4 & 6 pole 5692 the Hor's equivalent - It is like comparing a garden hose to a sewer pipe in fact a 56110 would be severely taxed trying to even come close and its a 25% larger motor . I just cannot see any magical magnetic and wiring combination that makes that motor so special and above all others .
      Quit using everyone else's examples and maybe post some of your own real world experiances .
      Yup.
      • Punisher 67
        • 1616
        #198
        Twissted I just want to apologize for being a little to gruff on my comments towards you sorry,,,, but the 12KV there is just no way - Hor claiming those numbers just blows me away
        • dana
          • Mar 2010
          • 3660
          #199
          Twissted I just want to apologize for a little to gruff on my comments towards you sorry,,,, but the 12KV there is just no way - Hor claiming those numbers just blows me away
          if youve had any dealings with this guy you would realize theres no need for apologies. he has been rude and obnoxious on many occasions to others on here.
          • twissted
            • 896
            #200
            motor werks
            Ok here is how I set up timming on my motors. I start wit factory guid lines and take temps and amp draw. I then set the timming to amp draw and keep a eye on the temp. What I get from that is the speed of the motors I also use different props. As for the quality of the SSS5694 motors I think they are great. as for thinking that they are better than the Lehner motors no. Go do think that theyare a steal at 99.00 dollars and would use one over a Neu motor of same size. This is my opinion and it is why I one one and will buy more in the future. As for buying a Lehner motor I would rather buy TP Power of the same size because I like the power to size that they produce, and they are more priced with my wallet in mine. you have your opinion and I have mine. I also think that tp sells more product for the reasons I just covered. They my not out run the lehner motor at the moment but they are a new company that makes changes to be the racers choice. I like that.
            twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
            • twissted
              • 896
              #201
              Hey I get it. And the thoughts we share are based on what we have used and lost in building and ther is a learning curve that I must face. I think that what Hor is claiming is based on the company that builds them. I'm thinking TP Power as they have alot of the same specs.
                Hears a tip for you,
                Just do not believe everything you read or hear.
                They like to till you what you want to hear,
                Just as long as it sell the stuff.
                Bull sh!t sells stuff, Just like sex does.
                • keithbradley
                  • 3671
                  #203
                  His opinion is based on experience.
                  Yours is based on nonsense.
                  You like the motors you have because they are the only motors you have.
                  Your assessment of Lehner, Neu, or even other brands of motors is about as valuable as your assessment of my back yard...you know nothing about either.
                  Feel free to comment on your experiences. Keep the rest to yourself.
                  It would be nice to keep some of these threads on track. Too many posts about your guesses just makes it hard for people to find the real info.
                  www.keithbradleyboats.com
                  • Cooper
                    • 1168
                    #204
                    Agree with Keith!!!!, I wonder why almost all the young kids buy Hondas and mitsubishi and the like and not buy Bugatti, ferrari , lambos, Porsche ? The later performs better doesn't it?
                    • Cooper
                      • 1168
                      #205
                      Interesting read guys, but my brain has bled enough, would be nice to ignore somethings but bad advice does have to be addressed. Hope you all well, you too twisted, and share some of your personally documented testing/builds ( enough of pics from others with the specs-show your own conclusions/results)
                        • 9481
                        #206
                        Agreed
                        • twissted
                          • 896
                          #207
                          Ok I will say it again. I run the SSS5694 1200 and also I run a pair of SSS3674 2075kv I run the 5694 on 8s and the 3674 on 6s. try to find a 3674 that runs on 6s! These motors are the real deal and untill you try one you will have just take the word of someone that knows nothing. LOL!
                          3.7v X 2075kv X 6s= 46065 RPM!
                          • Punisher 67
                            • 1616
                            #208
                            Twissted you can't run that kind of sustained rpm in a boat unless its a saws run - Are you using your motors in cars or buggies
                            • twissted
                              • 896
                              #209
                              Hey look at some zonda catamarans on you tube. I know they arn't mine but iot shows what I'm taking about. They come with the same motors mine did. In some of the videos they run full for min. on end. So now what?
                              Looks like this video runs for over 6 min on 6s 3300 mah. enjoy!
                              • keithbradley
                                • 3671
                                #210
                                No video = didn't happen.
                                Why do you think a smaller motor running 6s is impressive anyway? I have video of both 3665 and 3674 motors running on 8s...
