WTB OSE water jacket for leopard 40-74
  • Chuck E Cheese
    • 1684
    wtb OSE watercooling jacket for leopard 40-74. i need the shorter one that can be used with the clamp mount. let me know what you have and how much shipped priority to 96815
    thanks
  • britscoot
    • 656
    the red leopard jacket is shorter and will work
    http://www.offshoreelectrics.com/pro...eo-4050-jacket
    • Chuck E Cheese
      • 1684
      i was looking for one of the silver OSE ones. i just like to have the same ones in all my boats.. if worst comes to worse i will get one of those
      • Diegoboy
        Administrator
        • Mar 2007
        • 7247
        Chuck, Get'em while they're hot.
        • britscoot
          • 656
          good luck using a rear clamp with that one.
          • Diegoboy
            Administrator
            • Mar 2007
            • 7247
            I have to assume he needs this for the motor I tradded him.
            If so, the new black ones have the wires exiting out the back of the can, therefore
            IT WILL CLAMP.
            • Chuck E Cheese
              • 1684
              ya but i dont think the jacket will fit between the clamps without remaking the rails...
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                HUH? both jackets (silver short & silver long) are 48.5mm diameter.
                I don't get it
                • Diegoboy
                  Administrator
                  • Mar 2007
                  • 7247
                  Chuck, the rear clamp will go around where the wires used to exit on the red can ones.
                  you may just have to elongate the 2 holes a bit
                  • Chuck E Cheese
                    • 1684
                    ok here we go..... if you will notice the motor mount rear clamp sits right against the wires in the first picture. the cooling can sits right against the wires in the second pic. i do not think that the cooling longer can will fit in between the front and rear mounts. it isnt a mater of fitting on the motor but rather a matter of fitting between the mounts. i havent measured it and could be wrong but it doesnt look like it will fit to me.. i guess i will have to measure the mount and see if there is 57mm clearance between them but i remember reading somewhere it didnt fit. i dont think there is enough roon on the rails to make a new hole so i would have to fab new rails which i didnt want to do....
                    as for the diameter being 48.5mm that is the OD, not ID. i think they give that spec so you know it it will fit in applications such as riggers (and just so you know it wont fit a stock JAE, that is why i used a 1415 instead of 1515)
                    • Diegoboy
                      Administrator
                      • Mar 2007
                      • 7247
                      I mounted a 2" long cooling jacket in the same mount for the XL (36mm dia) motors.
                      The longer jacket is 2.2"... But I understand if you'd rather not.
