WTB 1/8th x .125 flex cables (2)
  • Alexgar
    • Aug 2009
    • 3701
    as stated above 5" or longer
  • Jeff Wohlt
    • 2740
    1/8" stub shafts to 125 cable?
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • Alexgar
      • Aug 2009
      • 3701
      yes sir
      • Jeff Wohlt
        • 2740
        That is a close fit....very close. Not sure I can drill those but will try a sample. How long of stub? 2" or 2.25"
        www.rcraceboat.com
        • Alexgar
          • Aug 2009
          • 3701
          got a cable thats about to quit on me and i need to get a cable for this hardware, ill used on my new cobra, Do you think it will work jeff
          http://www.hobbycity.com/hobbyking/s...5mm_(Hull_Only)
          • Alexgar
            • Aug 2009
            • 3701
            2" should work
            • Alexgar
              • Aug 2009
              • 3701
              fdm sells hugheys but if some one had a few laying around that be great
              • befu
                • Aug 2009
                • 1064
                Are you sure? I run 1/8" stub shafts with .098 cable in my boats, easier to make.
                It has been years since I have seen continuous diameter cables. Old way was to take a 1/8" flex cable, and cut the outer layer of strands off of the last 3/8". Then you measure the smaller inside cable and drill the 1/8" stub for that. solder it all together and polish the joint down to a continous diameter. We did this with 1/4" cable, but it should be the same.
                Can't drill a 1/8 stub with a .125 hole, they are the extact same size! Go 1/8 stub with .093 wire.
                Brian
                • Alexgar
                  • Aug 2009
                  • 3701
                  i had a 1/8 to .098 cant hold the power of a fiego L class motor they just break first or second time out
                  http://www.finedesignrc.com/hardware/125x125cable.jpg
                  • bustitup
                    • 3072
                    I may have what u need....I will let u know when I get home
                    • Alexgar
                      • Aug 2009
                      • 3701
                      sorry i pm you i misunderstood your post send some pics to my yahoo
                      • Alexgar
                        • Aug 2009
                        • 3701
                        home yet bustitup?
                        • bustitup
                          • 3072
                          Originally posted by Alexgar View Post
                          home yet bustitup?
                          sorry mine are 3/16" propshaft with .125 cable
                          • sailr
                            • Nov 2007
                            • 7128
                            sounds like you need to convert to wire drive
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                            • Jeff Wohlt
                              • 2740
                              Yep, I can make you a 1/8 x 062 wire drive that will hold it.
                              www.rcraceboat.com
