Before I vote Id like to hear the props and cons to this.
Proposal 4 - Modification and addition of rules for Electric 1/8 Scale Unlimited Hydroplane in Section 28 - Electric.
Reasoning:
Current rule:
E. SPECIALITY CLASSES
6. ELECTRIC 1/8 SCALE UNLIMITED HYDROPLANE
b. Motor Specifications
i) Power parameters for this class shall comply with class "T" specifications, as noted in rule D.1.a in this section
Note: “T” specs = Any amount and/or size of motors / 18.50 - 42.30 Volts / 12000 MaH max
Proposed rule:
b. Power Specifications
i) Approved Motors
(a) NEU 1527 1.5Y 850KV
(b) HET Typhoon 700-98 840KV
(c) Turnigy SK3-3994 850KV
ii) Twin motors are not allowed.
c. Drivetrain Specifications
i) Either a cable or hard shafts may be used, no gear boxes allowed.
ii) Any propeller may be used up to maximum of 57mm in diameter.
d. Electronic Speed Controls (ESC)
i) Any ESC may be used as long as it is rated to a minimum 130 Amps and rated to handle a minimum of 8S battery configuration.
ii) Anti-spark resistors are advised on all speed controllers.
e. Batteries
i) A maximum capacity of 8S Lithium Polymer (LiPo) batteries are allowed. The maximum mAh capacity of the battery pack(s) will not exceed 6000 mAh. Only LiPo batteries with a cell rating of 4.20 or less volts per cell are allowed.
ii) LiHV batteries with per cell capacities to 4.35 volts or higher are not allowed.
iii) Manufacturer’s minimum discharge of 30C constant but no higher than 65C constant is allowed.
Reasoning:
Current rule:
Proposed rule:
i) Approved Motors
e. Batteries
